Hi All,
My wife's 2003 2L 5 speed manual with 30,000 miles has just failed- the clutch went from showing no problems at all to staying about 1 or 2 inches off the floor and will not return to the normal position. I was thinking of trying to bleed the system as a first and simple attempt to repair it- do you think that this might be the cause, or from anyone's experience, is it more likely to be one of the hydraulic cylinders? There is no obvious sign of fluid leaking. Any suggestions or comments would be appreciated. Thanks, Paul |
You may need to replace the clutch, on one of my old cars the clutch pedal stuck on the floor and i found out that the clutch plate/disc had to be replaced
vDubOne Project 2001 2.0L NB GLS Dyno: (stock) 122HP Dyno: (2010) 186HP 13.695 quarter (2009) |
I'll also vote on the slave cylinder. Did that once on my '00.
Thanks for all the suggestions - paul |
F.Y.I if you change out your clutch/brake fluid, this problem will go away. I first experienced this on my Isuzu Trooper. Changed the clutch fluid which, came out looking like crude oil, pumped some fresh fluid through to get all the old fluid and dirt out before you button things up.
If the brake fluid is any other color then clear, it needs to be replaced. |
| 02M 6MT, Clutch pedal on floor, wallet out the door. | pueblorrado | Transmission Talk | 13 | 10-06-2009 04:16 PM |
| Blitzsafe adapter stays on | kaiimac | Car Audio | 6 | 04-07-2007 02:51 AM |
| Brake light stays on | BlueBeetle01 | 1.8 Liter Turbo | 6 | 05-29-2006 04:07 AM |
| ebrake and abs light stays on | angelusnhc | Technical Modifications | 6 | 04-18-2006 02:36 PM |
| airbag light stays on | mark | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 11-26-2005 02:50 AM |
