Clutch question - NewBeetle.org Forums
Old 05-29-2010, 04:26 AM
Default Clutch question
Just a basic question I have purchased a 1999 beetle w/ 5 speed manual trans. On average what is the life span of the clutch and is there a way to test if it is going. I did a test drive and car seem fine to me.
Thanks
Old 05-29-2010, 05:27 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
Condition/longevity of the clutch will depend entirely on the driver's ability, driving style and conditions. Some people can get 200-300k out of a clutch. Others could probably wear them out in 50k or less.
There is no real "test" other than putting your foot to the floor (on the gas) and seeing if it will slip under hard acceleration. Listen for throwout bearing noise with the engine idling and the clutch disengaged. Also make sure that the clutch releases completely. Worn out clutches will drag and make shifting difficult.
Which engine is in this car? TDI and 1.8T models have a dual mass flywheel which can be prone to failure. They get noisy (knocking/grinding sounds), cause rough clutch engagement, noise/roughness on engine shutdown...and if not replaced shortly after these symptoms show up...there is a very good possibility that it could fly apart and send shrapnel through the bellhousing, transmission and throughout your engine compartment.
The solution is to get a G60/VR6 clutch setup with a solid single mass flywheel.
2000 New Beetle GLS TDI
Old 05-31-2010, 02:07 AM
it is not a turbo
I thank you for the reply. I am getting the car on Friday so i will test how u said
Clutch pedal adjustment question grantsbeetle Transmission Talk 2 04-05-2010 03:30 PM
Clutch Question Oldbugman 1.8 Liter Turbo 11 07-22-2009 03:22 AM
An odd clutch pedal question boblamb58 1.9 Liter TDI 13 05-17-2007 09:27 PM
Clutch Master Cylinder question? ValkSmile Transmission Talk 3 05-16-2007 03:17 AM
Question about possible clutch chatter 2002bug0220 Questions, Issues, Concerns, or Problems with the New Beetle 0 05-27-2006 01:24 AM
