AT feels slippy, dash indicator does not agree with shifter position - NewBeetle.org Forums
Old 06-26-2010, 12:54 AM
Question AT feels slippy, dash indicator does not agree with shifter position
My Mom has a 1998 gas Beetle, auto, 90k miles. We've noticed that sometimes when taking off from a stop the trans feels like it slips between 1st and 2nd. It also happens less frequently between 2nd and 3rd.
Yesterday it was acting up for me, so I put the shifter in 3, but the dash indicator still had D selected. I did about 20 miles of city driving like this and the car shifted through all 4 gears without issue. It did not "slip" at all.
I also put the shifter in 2 and 1, and noticed that the dash indicator did not always agree with the shifter's position.
I'm thinking that while the shifter is in D that the trans is jumping into N momentarily. The dash indicator does not move to N when the trans feels like it is slipping. We've noticed that the issue seems to happen most frequently during easy starts, less often if you're getting on the throttle.
Does it seem that the shifter cable needs adjustment? Thanks!
EDIT: Just found the following thread that suggests the shifter cable needs adjustment. I'll start there.
Automatic Transmission shifter problem
Old 06-30-2010, 12:24 AM
Problem solved!
I followed the instructions in the above link. Loosened the silver 8mm bolt on top of the shifter cable, pulled the cable toward the rear of the car about 1/2", and re-tightened the bolt.
This has fixed the "slipping" from D to N during takeoff, and the dash gear indicator now matches the gear selector at the shifter.
It also fixed a problem we had with the trans taking too long to shift from R to D, like when backing out of a parking space.
Old 07-01-2010, 06:42 PM
Nicoliae's Avatar
Ames, IA, USA
Car: '99 Black GLS
Would you being willing to take a picture of where this cable is located?
Amy
'99 Black/Cyber Green GLS
Old 07-02-2010, 06:43 AM
llantolatino's Avatar
Vineland, NJ,
Car: White 98 Volky
Default HELLLP MEEEE AHHH lol
Originally Posted by gustagen View Post
Problem solved!
Please! HELP!
My beetle is doing the same and it BUGS me.
I dont know where any of this is located and dont know how to do it. If you can please send a pic of where it is located and directions on how to do it specifically, it would be sooo cool o you. I drive a lot and my beetl does the same I really like my car and would hate to see it break.
Old 07-09-2010, 01:47 AM
Default How to adjust automatic transmission shifter cable
Here are some pics to help you adjust your shifter cable. The photos are of a 1998 2.0 automatic Beetle.
I removed the air box to allow for more work room, but it is not necessary if you can get your hands and tools in there.
1. Loosen 8mm adjustment bolt near end of shifter cable.
2. Pry or pull the cable toward the rear of the car about 1/2 inch.
3. Re-tighten 8mm bolt while holding cable in place.
Check to see if your gear indicator on the dash matches with the one on the shifter. Good luck!
The two pics are also posted here:
imgur: The Simple Image Sharer
Old 07-19-2010, 02:53 AM
Vineland, NJ,
Car: White 98 Volky
Default Having trouble adjusting the cable :(
I have looked at the above images so many times, tried doing it myself... HAd a friend try to do it.... had a stranger try to do it... And no sucess. Am I doing something wrong? Or are there details that are left out? Please please help... I even burnt myself trying to loosen it.
Drivetrain feels loose? spinjector 1.8 Liter Turbo 6 07-04-2009 11:41 PM
Dash Lights with Key in On Position mybubbles Questions, Issues, Concerns, or Problems with the New Beetle 2 09-03-2008 05:11 PM
So... this is what love feels like! weldtech Miscellaneous Hoo-Ha Archive 22 01-31-2007 11:36 AM
Feels Faster Maggadog New Beetle Detailing/Cleaning 3 06-22-2006 05:50 AM
feels like i'm starting over callisto9 New Member Forum 20 09-27-2005 04:53 PM
