03 trans noise - NewBeetle.org Forums
Old 07-08-2010, 11:21 PM
Default 03 trans noise
My wife's 03 NBC 6spd auto, picked up a growl/ vibration in the front end. The trans shifts smoothly up and down, the noise & vibe start at about 30-35. No clicking or other cv shaft noises, the noise in consistant with the wheels straight or turned and seemingly equal side to side. With the vehicle of the ground, in gear and right front tire held solid it does seem louder on the left. Is the diff serviceable separately from the trans, as in separate fluid or shared. Can it be rebuilt seperately?
Old 07-09-2010, 12:53 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
Could be a bad wheel bearing.
2000 New Beetle GLS TDI
Old 07-09-2010, 01:28 AM
I was kinda hoping for a wheel bearing, I don't feel anything odd while spinning the wheels by hand. They both "feel" smooth, but at 35mph things change. It's up on blocks at the moment. I'll pull the wheels tomorrow and take a better look.
One quick question, how much fluid should I get when I pull the drain plug? I got almost a quart before it stopped, if I'm doing it correctly there should have been a lot less. There is almost no info out there on these 09G's.
Old 07-09-2010, 01:43 AM
Forgot to mention, its only got 56k well under the 100k failure point...
Old 08-15-2010, 10:45 PM
finally got around to looking at the car. Where can I buy parts for this trans, I'm leaning towards a diff issue. Fluid is used but ok, no metal in the fluid or in the pan. Pulled the plug under the center of the diff and the magnet is clean. How much play should there be with the axles still installed, should the trans end move or should it be solid in the bearing. If I grab the end of the axle shaft where it meets the trans it has noticeable wobble, more than most other fwd vehicles I've worked on. I'm feeling a bearing or spider issue causing my growl.
Old 09-12-2010, 10:01 PM
Besides VW where can I get tranny parts for this 09G?
FS: 1.8t + 6 speed trans Ghostride Parts and Accessories 2 11-10-2009 12:22 AM
Help Auto Trans :( kewl_guy33 Transmission Talk 2 03-11-2008 07:14 AM
Auto trans noise bdunner Transmission Talk 2 03-12-2007 07:48 PM
auto trans. robpad Questions, Issues, Concerns, or Problems with the New Beetle 1 10-23-2006 06:39 PM
