nieces beetle has dreaded 6 speed auto issues - NewBeetle.org Forums
Old 07-23-2010, 10:21 PM
Default nieces beetle has dreaded 6 speed auto issues
picked up a 2003 beetle convertible for niece. has the dreaded 6 speed auto issues, so I will be getting it straight for her.
I drove the car home and it ran well has the 2.0 engine with a 6 speed auto tranny.
car runs ok for first 15 minutes then tach shot up to 6000 rpms when i looked down and went into limp mode. switched it over to triptronic mode and it was in 3rd or 4th i dont remeber. wouldnt shift form there. stopped about 30 miles into our 60 mile trip and got gas when I got back in I ran it in trip mode and had no issues just got it into 5th for the rest of the ride.
So I have vag com and work in the auto industry. I have had many vw's so look forward to getting this one figured out with some help from the tranny gurus.
Ill run some codes and get back with what i find and then drive it a little more to get some more info on the issues.
Anyone know what parameters in vag com I should be focusing on at first in the tranny area to diagnose
thanks for help
Old 07-23-2010, 10:27 PM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
thanks for help
Have you tried simply resetting it to re "learn" driving styles?
Oh, i wouldn't say the 6speed auto has dreaded tranny problems.... To my knowledge, its vastly improved over the 01M 4 speed automatic it has replaced
Old 07-25-2010, 11:05 AM
Default read codes with vagcom
had random cylinder misfires on engine
tranny codes as follows
p0734 gear 4 incorrect ratio
00453 function limit due to overtemp
00641 atf temperature upper limit exceeded
looks like fluid got to hot from the p0734 code most likely.
I know valve body could be likely going bad.
I alos read something about a sleeve that can spin near the k2 clutch pack was wondering if this could be causing my issue.
The tranny seems to work fine in manual mode or in auto mode for the first 10 or 15 minutes.
well thats all for now till I get some more time to run it and see the exact symptoms.
Old 07-29-2010, 10:27 AM
Default latest update.
read codes about 5 days ago as posted above. cleared codes and have put roughly 300 miles on car and it is running well.
I have ordered a fluid kit for it and it will get its filter and fluid change on sat morning.
Old 08-07-2010, 12:37 AM
SoCal, Pacific Ocean
Probably just low on ATF and needs a fluid/filter change. Hopefully the VB didn't get fried.
Isn't the 5-sp tippy suppose to be a good unit made by Aisin?
Old 08-08-2010, 05:04 AM
You can always turbo it
WI, USA
When the cylinders misfire, the engine goes into limp mode which will mess with the ECU, and it will not allow you to pass a certain speed!
vDubOne Project
2001 2.0L NB GLS
Dyno: (stock) 122HP
Dyno: (2010) 186HP
13.695 quarter (2009)
02 TDI auto, few issues notfastenuff 1.9 Liter TDI 5 07-15-2010 10:28 PM
99 NB gls 2.0 auto - Issues = p* codes (very long, Intro + much info) Tomuza Questions, Issues, Concerns, or Problems with the New Beetle 1 02-16-2010 11:45 AM
Possible Upgrade: 2.0 Auto to a 2002 Turbo S 6 speed. Benderbeetle Rodrigues 1.8 Liter Turbo 8 01-13-2010 07:51 AM
5 speed or auto? robpad 1.9 Liter TDI 25 09-01-2007 06:41 AM
Six Speed AUTO (any hints ??) harley4jcs Transmission Talk 4 05-15-2006 09:19 PM
