1998 beetle rpms - NewBeetle.org Forums
Old 07-30-2010, 02:03 AM
Default 1998 beetle rpms
Hi I'm new to the forum. Just bought a 1998 beetle auto trans with a gas engine. I have question about the rpm's. At 70 mph the tach revs at about 3300. Is this normal? Seems a little high. Also I just had the transmission pan seal and filter? replaced. Thanks for an help you can provide.
Old 07-30-2010, 02:34 AM
Thats sounds normal. Thats about what I run in my 5-speed. The cars are perfectly happy running the high rpms.
Old 07-30-2010, 02:57 AM
Opelmania's Avatar
Dubbed Spiderman
Woodstock, IL, USA
Car: 98 2.0 5 Speed
That's where i run in my 5 speed also. I posted on a thread titled "RPMs" and it talks all about it. Not sure if there is a thread for an auto but just search RPM and you should find it. My NB likes running at 75 MPH and 3500 RPM. I commute 60 miles one way mostly hwy and average about 33 MPG on my tank.
Old 07-30-2010, 06:02 AM
Wingnut_rb's Avatar
Kennewick, WA, USA
Car: 03 Red Turbo S, 66 Ford Galaxie
My 6 spd runs at 2900-2950 at 70mph
Old 07-31-2010, 07:30 PM
My 2.0 2000 NB with an auto turns 3100 RPM at 70mph.
I would be concerned that is was slipping at 3300 RPM.
Who did the trans service?
Old 08-08-2010, 05:06 AM
You can always turbo it
WI, USA
At 70 MPH in my beetle, i run about 3800 rpms, in my four speed auto! That is usually normal
vDubOne Project
2001 2.0L NB GLS
Dyno: (stock) 122HP
Dyno: (2010) 186HP
13.695 quarter (2009)
Old 08-08-2010, 07:36 PM
3800 RPM at 70 mph? I would say something is wrong with the trans or your're running smaller tire than stock.
My car is a 2000 2.0 and I'm turning 3100 at 70 mph with a stock diameter tire.
Old 08-08-2010, 08:34 PM
woofster's Avatar
Toronto, Ontario, Canada
Car: 2000 VW Beetle TDI
Exclamation
Interesting...although I'm in a TDI, with my automatic, I'm well under 3,000 rpms when I'm on the highway, cruising at 110 km/h (~70 mph).
2002 Audi A4 1.8T Quattro
2003 Acura MDX Touring
2000 Volkswagen New Beetle TDI (sold)
Old 08-08-2010, 08:59 PM
Wingnut_rb's Avatar
Kennewick, WA, USA
I think the beetle has different final drive ratios for different MY/engine which would make RPMs diff as well.
Old 08-08-2010, 11:04 PM
Gear ratios for the 01M
2.0L gas
1st 2.714
2nd 1,551
3rd 1.000
4th 0.679
final drive 4.875
1.8T
1st 2.714
2nd 1.441
3rd 1.000
4th 0.742
Final drive 4.433
1.9 TDI (diesel)
1st 2.714
2nd 1.441
3rd 1.000
4th 0.742
Final drive 3.20
Old 08-11-2010, 04:46 PM
Supercharged98's Avatar
Fountain Inn, SC, USA
Car: 98 NB S/C'd 2.0L 5 sp
1998 2.0 AEG w/ 5 speed
runs at 3800 at 70 mph.
"Deutsche Stahl"
Old 08-11-2010, 05:06 PM
Stock tire size? Thats pretty high from what I've seen around here. I run about 3300 or so at 70 mph in my '99 AEG 5-speed
Old 08-11-2010, 05:19 PM
Wingnut_rb's Avatar
Kennewick, WA, USA
Final drive for my 6 spd manual is 3.88.
Old 08-11-2010, 08:13 PM
235/40/ZR18 ,stock was 205/55/R16
RPMs and Speed D2Beetle Questions, Issues, Concerns, or Problems with the New Beetle 3 03-21-2010 10:07 PM
Burning through rpms!!! (for the 2nd time this year!) _goREDgo_ 2.0 Liter Gas 1 11-21-2009 02:12 AM
RPMs revving high on the highway kngriffin Transmission Talk 8 09-14-2009 02:34 PM
Missing at Low RPMs.... Golgade 1.8 Liter Turbo 2 06-19-2009 03:36 PM
no speedo,fuel or rpms what's up with that? volksey66 Questions, Issues, Concerns, or Problems with the New Beetle 7 06-26-2006 03:32 PM
