transmission compatbility - NewBeetle.org Forums
Old 08-23-2010, 04:26 PM
GLUVBUG's Avatar
orange county,
Default transmission compatbility
Hello:
I have a 1999 2.0 GL and the transmission is done. I pulled the tranny and the part# is DZ027061
I purchased a used tranny that I was told came out of another NB but the part # is DZ012117
Are these two transmissions compatible?
Thanks,
Jeff
1999 2.0 333,333+ miles
Old 08-23-2010, 04:31 PM
noR's Avatar
Administrator
Jackson, MS, USA
thaose are strange part #'s.
Got any other identifying marks or information?
If it's an 02J transmission, it will probably bolt up just fine. If it's automatic you may have problems.
noR | me | Phrog
PHROG
Old 08-23-2010, 04:48 PM
GLUVBUG's Avatar
orange county,
Nor:
Thanks for the quick reply...those #'s i listed might be serial #s?
Anyhow after looking at both transmissions, they look identical 5 speed manual and looking inside the bell housing I did see the
actual parts # of 02J 301 107 C
I think I'm good. My beetle has been out of service for well over a year stuck at 342,000+ miles
In addition to r&r the transmission, I will replace the flywheel, pressure plate, clutch disk, to bearing, clutch fork and spring.
All coolant hoses, ps hoses, valve cover, and various suspension components will be replaced.
Jeff
could it be the transmission??? vianka89 Transmission Talk 4 03-09-2010 03:27 AM
transmission cfree3 1.9 Liter TDI 2 12-16-2009 12:19 AM
transmission help KatieScarlet New Member Forum 2 10-25-2008 08:00 PM
I need a little help with my transmission SLC Dubster Transmission Talk 2 03-18-2007 02:21 AM
Transmission ? ttha33 2.0 Liter Gas 2 02-20-2007 02:21 AM
