Whine in M/T - NewBeetle.org Forums
Old 08-29-2010, 01:18 AM
Killer Bee02's Avatar
Default Whine in M/T
Got a whine in my tranny when accelerating. Goes away when you let off gas. Could this be output bearing or output sleeve. Do you have to pull transmission to replace this? Bryan
Old 08-29-2010, 05:19 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
Checked your fluid level lately?
2000 New Beetle GLS TDI
Old 08-30-2010, 12:41 PM
Not in a while. But maybe new would be good. Any suggestions on brands??? Have read some pro's and con's. Is the vw factory brand the best? Thanks, Bryan
Old 08-30-2010, 03:16 PM
I would start by checking the fluid level and possibly changing, we do have a selection of different transmission fluids available.
The manual tranmissions are not as picky about fluid as the automatic cars, but we typically suggest using Redline MTL. The MTL is a good all around fluid for most temperatures / climates while the MT90 is a bit heavier and does well in warmer climates.
Volkswagen New Beetle 1.8T > Maintenance > Transmission > Service Kit - ECS Tuning Inc
Old 08-30-2010, 03:49 PM
DZLBUG's Avatar
I Am Breitbart
Redline is good, but many guys are going back to the VW fluid. The old G52 has been superceded by G60 and now G70 which is a very good fluid.
Old 09-06-2010, 09:57 PM
Could have a hard time finding the redline around here in redneck country!! LOL!! Thanks for the help with this, will do the search thing. Thanks again, Bryan
Old 09-06-2010, 10:41 PM
DZLBUG's Avatar
I Am Breitbart
In a pinch, just find any GL4 rated 75w90 gear oil, preferably synthetic.
Stay away from GL5 or GL4/5 oil as the GL5 additives are not good for the brass syncros.
Belt whine savethebluths.org 2.0 Liter Gas 9 07-24-2009 11:22 PM
New whine bmoore106 1.8 Liter Turbo 5 12-13-2007 07:02 PM
Head Unit Whine KittenPoker Car Audio 2 09-01-2006 05:05 AM
whine on acceleration mystix 1.8 Liter Turbo 11 12-20-2005 11:58 PM
