1998 trouble shifting into first and reverse - NewBeetle.org Forums
Old 09-02-2010, 02:49 PM
Default 1998 trouble shifting into first and reverse
I have a 1998 gas Beetle and I have been having trouble shifting into first gear and reverse. I have to push the shifter down to get into first and I have to push it further down to get into reverse. Its at the point now where I can barely get it into reverse because the shifter has to be pushed down so far. And more recently I have also been having trouble getting into second gear. All other gears are fine.
Old 09-02-2010, 03:20 PM
Check your shift linkage. It could need adjusting or the plastic piece in the linkage is failing. Mine started to be hard to get into gears before that piece failed and I was left with only 3rd and 4th gear. The '98s and '99s were the only NBs that had this plastic component and they have a weird MkIII/MkIV combined linkage setup. Its crazy.
Old 09-02-2010, 03:34 PM
Is this the part that you are referring to (part#:1J0711256)?
Old 09-02-2010, 03:42 PM
I'm not actually entirely certain of the part number or what it looks like. I took it to my local shop. I looked enough in the bay to know that there was a broken piece and it was plastic I do know that it was a $70 part though. And as far as I know, there is no metal replacement.
Old 09-02-2010, 11:30 PM
DZLBUG's Avatar
Big Stig
Sauk Rapids, MN, USA
Take a look at the linkages but I'm thinking this may be in the shifter box in the car. They are prone to issues as well.
2000 New Beetle GLS TDI
Old 09-22-2010, 04:08 PM
I replaced the Shift Carrier (part#:1J0711256) but that ended up not being the problem. It turns out the cable needed to be adjusted. There is still a problem though; I am having a hard time adjusting it. If I adjust to far one way I cant shift into first, if I ajust to far the other way I cant shift into fifth. I cant seem to get it into a position were I can shift into both easily. Ive been told that the bushing might need to be replaced but I can not find replacement bushing for the 1998 model. Does anyone know of a solution for this?
Old 01-18-2012, 07:23 PM
NEW BEETLE MECHANIC!!!
Camarillo, CA, USA
Car: 1998 Beetle 2.0 Base
Default Me too!!!!
I'm having problems rigging the cables correctly as well. Cant seem to find the sweet spot where it goes into all the gears correctly. How did you fix your problems? Any advice on the rigging/adjustments? gotta get my sons car back on the road!
Old 01-19-2012, 01:56 AM
IndyTom's Avatar
Indianapolis, IN, USA
Here are some links that might help:
Volkswagen Group Shift Linkage Adjustment for year models 2000-2010 - YouTube
How to adjust your Volkswagen manual transmission shifter cables
(Move down to the MKIV section)
Trouble Shifting into 5th Gear! Help beetlejuice27 Transmission Talk 5 06-17-2009 06:49 PM
won't go in reverse weluvbugs Transmission Talk 4 04-06-2008 10:41 PM
auto tranny having trouble shifting co-ed_bug Transmission Talk 4 12-09-2006 07:10 PM
Reverse Lights? Mr.Yellow Styling Modifications 3 11-13-2006 07:24 PM
Dealer diagnosis for trouble shifting $$$ my99vdub 2.0 Liter Gas 0 05-02-2006 02:52 AM
