Hello, I am experiencing problems with my 2001 vw beetle 2.0 gas automatic. The car is really sluggish off the line because it does not automatically downshift into first when I stop. The car also does not shift into overdrive either. If I manually shift the car I can accesss first,second and third but still no overdrive. I have read in other posts about the car going into "limp mode". How do you get the car out of limp mode? HELP!
Limp mode. You get rid of limp mode by fixing the problem that is causing it. Scan the TCM with VCDS to see what the problem is. Likely culprit is a speed sensor but there are other causes.
Best way though is to just scrap the autoturd and bolt in a 5 speed.
lol, "autoturd"
Got an Engine or Airbag light but can't afford a Vagcom or trip to the dealership?
Need help finding a local mechanic or shop? <<credit to Fl_Bug>> (o \__(vw)__/ o) (add me!) |
| 98 stuck in 3rd gear? What to do. | arbiter | Transmission Talk | 12 | 01-07-2011 02:49 AM |
| 2000 New beetle Auto trans stuck in 2nd gear | manshoon | Transmission Talk | 3 | 04-01-2010 10:21 PM |
| Transmission stuck | rramirez26 | Transmission Talk | 1 | 03-02-2010 12:52 AM |
| 5 speed stuck in gear | speedsk8er | Questions, Issues, Concerns, or Problems with the New Beetle | 8 | 08-09-2006 08:13 PM |
| Transmission falling out of gear | Flopka2 | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 05-03-2006 02:25 AM |
