2004 TDI Randomly Reving Up - NewBeetle.org Forums
Old 10-26-2010, 02:28 AM
Default 2004 TDI Randomly Reving Up
My 2004 TDI New Beetle will randomly rev up while driving it. It has an automatic transmission. It will suddenly go from 2100 rpm's to 3000 rpm's and suddenly drop back down to 2100 again. It will do this multiple times and then it will run fine for awhile and repeat the same thing over. It does not shift gears when this happens. I cannot find anything in common from one time to another. Any ideas? It has approximately 101,000 miles on it.
Old 10-26-2010, 03:31 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
Whats the maintenance history?
This is the 6 speed DSG, it is technically an automatic transmission...but internally it is nothing like an automatic. It is an electronically controlled manual transmission.
First off, this transmission has very specific fluid that MUST be changed every 40k miles. My fear is that this has not been done and damage has occurred as a result. At over $6000 for a replacement transmission, this is unfortunate.
But before you get too worried, the first thing to do would be to get it scanned for codes with VCDS. Generic OBD scan tools do not work. Depending on what you find out, a transmission fluid change is the next likely step.
2000 New Beetle GLS TDI
Weird noise when reving... vwnb01 Questions, Issues, Concerns, or Problems with the New Beetle 4 09-05-2008 11:08 PM
Blue_Stinkbug 2004 Galactic Blue TDI Blue_Stinkbug Photos: New Beetles 18 10-30-2006 09:56 PM
RHD 2004 TDi - UK going retro neil76 Photos: New Beetles 7 07-12-2006 09:03 PM
2004 TDi Noob Questions!!! BeccyBug New Member Forum 11 07-04-2006 07:37 AM
mk2subzero's Ride - 2004.5 GL TDI mk2subzero Photos: New Beetles 8 03-17-2006 12:06 AM
