How-do. Sister's got a 2000 2.0 with 147k...bought about 6 months ago. Whilst driving one day, she heard a crunch and a pop. Turned out someone had done previous work to the half-shaft and either did not tighten the bolts, didn't use lock-tite, or simply did not put the inner bolts back in...all were missing but for 2 that were sheared off.
I went to the stealership to order new ones, told him what i needed, gave him the vin, and he came back with part # N-911-082-01. These are definitely the wrong bolts. The ones I got from him are WAY too long and at least one size too small as far as diameter goes. Does anyone know the correct part number for these bolts? It's obvious at this point that my dealership's parts department is filled with retards, so I'd rather just go in with a part number. Pics - These are the bolts I need - ![]() ![]() This is what the idiot gave me - ![]() ![]() Thanks, Kris |
He gave you bolts for a manual transmission which uses different flanges/axles.
You need these: Home Page > Search > N90991002 > ES#8636 Bolt, With Polygon Socket HD, 10x23 - N90991002
Well, I went to the dealership and yelled at the parts guy for being a complete idiot. Of course noone in town has the things, so he over nighted a set in from Houston. I needed the use of my rack, so I went and got the same size bolts in a grade 8...they work wonderfully, but since they're hex-head bolts, they rubbed a bit on the axle when putting them in and you can only tighten them with an open-ended wrench. I only had to move it about a half a block, so I'm not all that worried about it.
Anyway, he ate the cost of the new bolts and the overnight shipping and told me to just keep the other bolts and the plates that are used with that tranny, so if anyone needs the 6 bolts and 3 plates for the manual tranny let me know and they can have them for mailing cost. |
| cam shaft sensor help | ashleybrownlee | 2.0 Liter Gas | 13 | 08-23-2010 09:31 PM |
| Half shaft for 04 vert | TarHeel Beetle | 2.0 Liter Gas | 0 | 11-06-2009 08:53 AM |
| messed up half shaft? | VeeBugTurbo | Transmission Talk | 1 | 11-02-2009 09:38 PM |
| drive shaft wobble? | fuehara | 1.8 Liter Turbo | 9 | 08-19-2007 09:32 PM |
| crank shaft | gearhead1972 | 2.0 Liter Gas | 6 | 01-24-2007 01:24 AM |
