Thanks for the great replys now that iv got a better chance to look at her {99 beetle 2.0 auto} it has a split boot ov cv axle near transmission left side the car hesitates to jump in gear first 10 secs and when its cold some times it jumps out of gear 1 or 2 times once warmed up it stays in gear no leaks also checked atf level open plug and at least a cup came out while cold need any ideas what might cause a wine that started after a 100 miles and got louder ? any help appreciated thanks in advance .
Did you do this with the engine off? If so, the trans is now underfilled...though it might have been underfilled before. The engine has to be running and the transmission has to be up to operating temp before checking the level.
Then engine must be running to get it up to temp, without the engine running, it will not get to temp.
Also as I have mentioned before, the trans takes two lubricants, one in the transmission, one in the rear diff/trans axel area. To access the rear diff filling hole, you must remove the VSS (vehicle speed sensor). |
Yeah no kidding. But when many (particularly the inexperienced) people read these directions; they will shut off the engine when it gets to temp, and then pull the plug. Some people are wary of getting underneath a car when its running or opening something up when its running because they think it will spray all over.
Ok started car warmed up check fluid 1 qt low seems to be jumping in gear quick and stay in gear. also found two posible plugs top of transmission does any one know which one it is ? and if its on top of shift {like both of these are} then how do you know when its full? i uploaded a pic of top of tranny circle possible plugs ? 1 or 2?
Ok i finaly broke down and take the old tranny out. I poped the diffrintial cover and to no amazement she is bone dry and as feared messed up housing ouch . ok here i am do i put a auto ecv back in her or go to a manuel ??? I was told that a manuel would not work that my engine was mated to the auto transmission and that several faults would happen if i put in a manuel?? as always any help thanks in advance.
5 speed swap is easy, this write-up is for a TDI...but the general concept and wiring is pretty much the same. Many gasser owners have used this as a guide:
Project Kill Da Auto Wabbit!, Or how I learned to love the Manual Swap - TDIClub Forums Unlike TDI's, your 2.0 ECU cannot be recoded. So you would have to find a used 2.0 manual ECU. Not hard to do. Everything else is just remove and replace; and simple wiring for the cruise cancel, clutch interlock and reverse lights. |
You're going to need a 2.0 ECU out of a 99 Beetle or 99.5 Golf/Jetta. Also make sure the transmission you are getting is out of a 2.0 car (NB, Golf, Jetta), otherwise the gear ratios will be wrong.
All of the other parts; clutch pedal, mounts, starter, shifter, etc etc can all come from any A4 platform car regardless of engine. |
| Oy! My back! Anyone got a recommendation for some beetle back support? | morkus64 | Miscellaneous Hoo-Ha | 7 | 05-11-2009 04:27 AM |
| Vee Dubs and Texas Nights 16 in Houston Texas | Captain Otto | USA: Southwest | 2 | 09-26-2008 07:56 PM |
| 1958 Beetle is Back Home | bsvwoc@msn.com | Photos: Other Rides | 9 | 04-21-2006 12:57 PM |
| Back home | Blue_Stinkbug | Miscellaneous Hoo-Ha Archive | 0 | 01-15-2006 07:04 AM |
| Vee Dubs and Texas Nights 13 photos in Houston Texas | Captain Otto | Photos: Get Togethers | 3 | 11-07-2005 04:43 PM |
