Am I supposed to pull the codes out of my a$$? Or would you like to share them with us?
Eric I think you should take it to a tranny shop or a VW dealer before anything else is damaged or it gets worse. Check the stuff I emailed you about for starters (service history) and find out. I assume you knew about this when you bought it last week and got a good deal out of it, if not all I can say is ouch and get it diagnosed. Keep us posted and good luck!
True, but it was mostly said in jest. I just get a bit annoyed when people ask questions like this and give so little info. If you are going to ask a question, at least try to help the person you are asking to help you. |
I'm not really an a$$hole, I just play one on the internets.
If you really knew me, I am plenty humble. I just get in a hurry sometimes, like when I'm just checking the forums before work, and sometimes I'm a little testy if I haven't had my coffee yet. I also like to lip off a little now and then, its all good-natured...I just don't do a very good job at sugar-coating things. If you don't like it, don't read it. ![]() |
MORAV |
before you read the TCM, you could try checking the transaxle fluid. there's a dipstick for it. it's e-z to check. if its low, that could be your problem.
http://unitwan.co.nr/beetle.htm |
Yes you can. Dealer says "lifetime" but no fluid should be anywhere in a car for 10+ years. To do the job correctly, I believe you'll need access to VAG-COM.
| Stumbles when pushed | Lnzbug | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 08-12-2009 04:28 AM |
| Overdrive | sammyh | Transmission Talk | 1 | 11-06-2007 05:35 PM |
