TCU Location - NewBeetle.org Forums
Old 01-07-2011, 03:11 PM
CIncinnati and Louisville, OH and KY,
Car: 1999 VW Beetle 2.0
Default TCU Location
Can someone please tell me where the TCU is located on a 1998 Beetle and the best way to get to it?
Thanks
Chuck
Old 01-07-2011, 05:38 PM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
Thanks
Chuck
TCU?
Did you mean ECU? If you did, its like changing the cabin air filter but on the side in front of the driver.
Old 01-07-2011, 06:57 PM
Originally Posted by Fl_bug View Post
TCU?
TCU - Transmission Control Unit I thougt I read somewhere it was behind the glove box.
Old 01-07-2011, 07:13 PM
Fl_bug's Avatar
Miami, FL, USA
Oh that i have no idea.... But i drove without a glovebox for 3 months and I can can tell you its not much back there lol.
What exactly are you trying to do?
Old 01-07-2011, 07:14 PM
TCM is what I think its usually called (Transmission control module). Probably why FL_Bug wasn't sure.
Old 01-07-2011, 10:47 PM
Yup that is what I've always called it. But the repair Haynes manual I have says TCU so I figured TCM wasn't good enough for VW and they had to change the name.
Old 01-07-2011, 10:51 PM
Howdy,
Check this out and I think you'll get what I'm up against.
Check engine light, will not shift PLEASE HELP
D Solenoid and Filter
Thanks,
Chuck
Old 01-07-2011, 11:37 PM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
It would really be helpful for you, and for us, if you'd keep everything in one thread. No need to clutter things up with multiple threads on the same issue.
The TCU/TCM (same thing - interchangeable) is underneath the dash on the right side. Remove the front/center dash panel (it just pushes forward). Then remove the panel to the right. Once you get that panel out of the way, there will be another panel underneath it. Remove that panel, and the TCM will be right there. The only other thing in there is the cabin filter.
Why do you want to access the TCM? Do you have reason to believe it is bad? IIRC, you are having shifting problems and some codes relating to communication problems? It could be the TCM, but it could just be a dirty/bad connection at the transmission end.
I don't have time to go searching through your other threads to confirm this...which is precisely why I told you that you should keep everything in one thread. If I'm going to take the time to help you, I don't want to waste time trying to get the rest of the story or to see what has already been covered.
2000 New Beetle GLS TDI
Old 01-08-2011, 01:06 AM
Yup DZLBUG, you are right I should have kept it on one thread the problem was the original was on the wrong thread. I originally thought it was an engine problem. So I tried to correct that by moving to the Tranny forum.
I had a P0768 code, D solenoid. I checked resistance on all solendoids at the case connector, all good. Dropped the pan, every thing looked great. Since I can't fire the Solenoid and test it I need to rely on restance checks. Once I have the TCU off I can wring out the cabling from there. Then change the TCU and see if that works. If not I will put a torch to it. Not really, I'm just frustrated right now.
location of A/C components bavareze 2.0 Liter Gas 5 10-31-2010 05:44 PM
CD Changer location? KoolWhip Car Audio 2 05-13-2009 04:59 PM
location dianepbt Texas New Beetle Round Up 2 06-26-2008 07:13 AM
U.S. VW plant location mel72349 Rumors and Insights 12 04-01-2008 01:29 AM
ECU Location? johnmichael 1.8 Liter Turbo 2 03-13-2007 03:30 AM
