What Should I Know to Replace Speedometer Drive Gear? - NewBeetle.org Forums
Old 01-23-2011, 01:41 AM
Linden, MI, USA
Car: 1998 2.0L Auto Beetle
Default What Should I Know to Replace Speedometer Drive Gear?
I need to replace the speedometer drive gear (9 in attached picture)in a 1998 auto Beetle. I have seen a couple of post where this has been done. I know I need the gear, a gasket, tool for half shaft bolts and gear oil. Is there anything else needed other than normal tools? I was disappointed to find that this does not seem to be covered in the Bentley manual. Any help with steps required would be greatly appreciated.
Old 01-23-2011, 11:57 PM
Linden, MI, USA
Just removed the cover on the back of the differential case and the drive gear is not there - in the normal location. I could see the driven gear on the speedometer drive/dip stick but the gear that drives it is not there. Must be in the bottom of the case somewhere, could not see too well. I guess the next step is to disconnect the right half shaft and remove the drive flange, not sure exactly how to install the new gear yet.
Old 01-24-2011, 12:33 AM
2004NBTURBOS's Avatar
Peace Love & T.o.D.
Ocean View, DE, USA
Car: 1st 2000 GLX now 03.5 TS
I dont know much about the autos but my 2000GLX 5spd broke the sender in the trans. It lasted about 2 days till it lunched the trans. And I mean lunched, there was shrapnel like you wouldn't believe. Cost me almost 3g's to replace. Sorry I cant help much, just thought I would share my little trans misery.
Please Help: My Beetle Wont Move/Drive in any gear lasvegasbeetle 2.0 Liter Gas 2 04-21-2010 06:02 PM
2.0l front wheel drive to 4wheel drive??? huck731 2.0 Liter Gas 3 11-22-2009 12:56 AM
Speedometer magicguy Questions, Issues, Concerns, or Problems with the New Beetle 8 01-18-2009 12:58 PM
Anyone replace final drive fluid on an 01M ? ninsei Transmission Talk 1 02-13-2006 04:53 PM
anybody replace the final drive fluid on an 01M? ninsei 1.8 Liter Turbo 1 02-10-2006 02:41 PM
