OK had a glitch
today, actually it was several weeks ago. When I performed the Master Cylinder replacement, I made a mistake, I moved the brake pedal so I could get a better angle on the clutch pedal bolt. When I pressed the brake pedal a fine mist of brake fluid sprayed the side of the cylinder head soaking the water flange and hoses. Come to find out the (mineral oil) brake fluid softens the rubber, makes it swell and then it deteriorates.I have decided to replace these two lower hoses (one of which is actually two hoses) on the water flange before putting the new clutch in.
My NB Family... Last edited by D2Beetle; 01-02-2012 at 10:57 PM.. |
OK, the new hoses are installed and I also went ahead and replaced the oil cooler o-ring.
The new clutch is also installed; so next weekend the transmission gets re-installed! ![]() |
Got the transmission back off this weekend; I had reviewed my notes on the work I have done so far and I only torqued the flywheel bolts to 30Nm
and they should have been torqued to 60 Nm... Lets just say that I did not read the last line, at the bottom of the last page of the manual. So the all important questions is; will I be able to finish up this project without making another mistake this weekend? ![]() Last edited by D2Beetle; 02-26-2012 at 08:51 PM.. |
Lets just say that this project is turning into my Nemesis and I still have to clean up the gear oil under the car. My neighbor heard my
and brought over some beer.Quote:
Anyway, the transmission is almost back on; having difficulty lining up the spline. |
Seems like you are almost there. Hey, since it seems you like the practice. I will come down and you can work on my clutch. I will even bring the beer prior to when the cursing starts ![]() |
Oh, I like the practice, but the real questions is, can you afford that much brew? ![]() |
Sam Adams is pretty Good. It's also the highest Calorie beer you can drink
But it does have flavor. Never really had St. Pauli Girl Beer. I have seen it but never tried it. Now if you like Sam Adams you will probably like Bitburger and Warsteiner and Paulaner Beer. True German Bier = YUMM. ![]() |
Transmission is in
and I will be driving it soon.! Although I did get my pinky mashed between the axle housing and the sub-frame getting the trans into its proper aligned position. |
| New Headlights Woes | Fl_bug | Paint and Body | 2 | 10-14-2010 04:13 PM |
| A/C woes... | mgwerks | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 06-27-2007 07:15 AM |
| A/C Woes | Formcar40 | 2.0 Liter Gas | 2 | 02-28-2007 04:39 PM |
| CEL Woes | ImBuggin | 2.0 Liter Gas | 9 | 08-11-2006 10:11 PM |
| 2.0 woes | callisto9 | 2.0 Liter Gas | 66 | 11-05-2005 07:27 PM |
