'00 NB Transmission Noise - NewBeetle.org Forums
Old 05-02-2011, 12:24 PM
Mr_Eddy's Avatar
Drive Happy!
Cedar Rapids, IA, USA
Car: 2000 NB GLS 1.8T, 2011 Golf
Default '00 NB Transmission Noise
Yesterday while driving, the tranny starting making a loud tapping noise when I would either let off the accelerator or depress the clutch. Could not feel anything through the pedals. The tapping frequency tracks with the road speed.
Even the slightest acceleration would make it go away, or at least make it so I could not longer hear it.
About 205,000 miles on the car. Any ideas on what this could be? I've found a post on Vortex about a 2.0 Jetta with similar symptoms. Suggestions for that were rivets in the diff gave out or the small output bearing might be failing. He never said what it actually was and just replaced the tranny.
Thanks
Ed
My Beetle - "Sluggo" I keep thinking of getting "grown up" car, but then people might expect me to grow up.
My Wifes Golf - "Luna"
As quoted from my 12 year old daughter in class one day...
"If life gives you lemons, make Lemonade
But if life gives you limes, make Margaritas"
I have no idea where she got that idea from
Old 05-23-2011, 07:33 PM
Mr_Eddy's Avatar
Drive Happy!
I finally had time to get Sluggo in the garage and jacked the front end up. (been out of state a lot this year working)
Spinning one wheel makes the other spin in the same direction and I can hear the tapping noise, though just barely coming from the differential area.
So it looks like something in the diff gave out. Just not sure what.
Any experienced guesses on if I should be able to replace the diff (or rebuild it) or replace the tranny?
Also, is there a good manual on tearing down the tranny? The Bentley just shows removal and installation.
Old 10-06-2011, 07:02 PM
ricka1's Avatar
ricka1
Waynesboro, PA, USA
Car: Y2K 1.8T
Unhappy I've got the same symptoms!
Any luck with the differential? I've got the exact symptoms and I'm dreading the potential repair bill. Any good news or advice that might belay my apprehension?
Thanks!
Rick
Old 10-10-2011, 12:56 PM
Mr_Eddy's Avatar
Drive Happy!
Thanks!
Rick
After I got the tranny out, it was obvious it was not the diff. Spinning the axle hub you could hear the tapping coming from the tranny side.
I ended up finding a low mileage used one for about $350, so I didn't bother opening it up to see what it was.
Probably not what you wanted to hear.
transmission cfree3 1.9 Liter TDI 2 12-16-2009 12:19 AM
Is my transmission out? VW_Lover89 Transmission Talk 2 07-02-2009 05:01 AM
wtb. 2.0 transmission fuel110 Parts and Accessories 9 06-25-2008 04:49 PM
Transmission Noise Jade'sBug Transmission Talk 1 04-29-2008 01:35 PM
I need a little help with my transmission SLC Dubster Transmission Talk 2 03-18-2007 02:21 AM
