'01 cluch issue 5 Speed 1.9 TDI - NewBeetle.org Forums
Old 05-05-2011, 11:43 AM
Irvington, VA, USA
Car: 2001, TDI
Default '01 cluch issue 5 Speed 1.9 TDI
While diagnosing a Mass Air Sensor issue yesterday, My cluch peddle fell to the floor, and now I cannot shift. About 12 Months ago new cluch, pressuer plate and I think flywheel were repaird while on a trip to SC. Have not had any issues at all since that time. All fluids are new and clean.
I was able to "pull" the peddle back up, and tried bleeding out the system, but there is not enough "throw" for shifting. I removed and reinstalled the Slave Cylinder which seem loose, but that did not help. My son (primary driver) said the peddle had a hesitation comming back up that is different from usual. My question is, Is this a slave cylinder isse, a master cylinder issue, a combo of both , or a clutch/fork issue.
I guess the old remove and replace will have to occur with the cylinders befor I drop the trans for a cluch inspection.
16885 Vehicle Speed Sensor - Speedo Issue v12bug 1.8 Liter Turbo 7 10-18-2010 12:22 PM
Speed Sensor Issue giink 2.0 Liter Gas 1 06-29-2010 12:24 PM
02G / GHE 6 Speed TipTronic To 02M 6 Speed Manual Swap! sledge0001 Technical Modifications 31 07-22-2009 04:38 AM
Alarm Issue and Inside Light Issue-HELP! tinarie01 Questions, Issues, Concerns, or Problems with the New Beetle 4 01-02-2007 06:36 AM
