Totally confused! - NewBeetle.org Forums
Old 05-22-2011, 09:07 PM
Ilwaco, WA, USA
Car: 2007 Beetle GLS
Default Totally confused!
Ok, like the title says, after reading tons of posts found by doing a search, I'm totally confused about the transmission in our 2007 NB.
I know it is an 09G transmission, I know it is a Tiptronic 6-speed and not a DSG. I also know the Tiptronic is supposedly a different transmission than a DSG. Lastly, I know I need to change the fluid and filter every 40K miles.
So what I am totally lost on is which filter I need to get (I've seen a canister type and one found in the pan)? What type (and how much) transmission fluid? And most importantly, how to drain and fill the transmission?
I've read through lots of info on a DIY for the DSG transmission where you drain and fill it through the pan with a special hose and filler tube, and monitor the fluid temperature with VAG-COM (which I have). But as I said, I have 6-speed Tiptronic not a DSG. Does the method for the DSG drain and fill also apply to the 09G 6-speed Tiptronic?
In short, if anyone can tell me the type of filter, the type and amount of fluid I need, and a good DIY on how to do it I would be grateful.
Thanks,
Glenn
2007 VW New Beetle 52K (hers)
2002 VW Jetta TDI 137K (mine)
1995 Volvo 850 Turbo 229K (kids)
1983 Mercedes 300D 251K (diesel commuter)
1965 Corvair Corsa 97K (fun car)
Old 05-23-2011, 03:29 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
Buy a Bentley manual, has all the info you need.
2000 New Beetle GLS TDI
Old 05-23-2011, 04:00 AM
dnyed's Avatar
Portland, USA, USA
Car: 2002 New Beetle 1.8T GLX
Didn't they only use the DSG in TDIs?
Former VWs:
2003 NB TDI - Galactic Blue
2005 NBC 1.8T- Tornado Red
2003 NB Turbo S - UniRed
Currently:
Old 05-23-2011, 04:53 PM
DZLBUG's Avatar
I Am Breitbart
04-06 TDI' s only
Sent from my DROID2
totally clueless! Vic2165 Car Audio 11 02-16-2009 06:29 PM
Totally Screwed Up; Fixed!!!!! chunkybabygurl Paint and Body 8 07-24-2007 07:33 PM
DannyARIZONA totally rocks!!! Breez Market Place Archives 7 03-28-2007 11:07 PM
Totally off topic (non VW question) my99vdub Miscellaneous Hoo-Ha Archive 3 09-13-2006 05:40 AM
BluBarnBug-98 GL totally stock Kickeroo Photos: New Beetles 5 02-13-2006 06:07 PM
