Auto trans - good/bad years? - NewBeetle.org Forums
Old 05-25-2011, 05:34 PM
Car: 2000 GLS - 2.0L - Bright Blue Pearl - 5 speed
Default Auto trans - good/bad years?
All right, let me spin the auto trans issue one final way. Fyi, looking to buy like a 2000-2003. Are any model years know to have reliable auto trans'? Any model years to stay away from in terms of the auto trans? And finally, how do you tell if an auto trans is failing? Thanks again! George in Philly.
I know a stick is a safer way to go but, if someone is offering an older creme puff w an auto trans and lower miles let's say I'd hate to pass it up.
Old 05-25-2011, 05:44 PM
None in that year range as far as I'm aware. The auto in those cars is the O1M, which is junk. Failure before 150k miles is extremely common. Some of the newer transmissions may be ok, but VW has issued a recall for the valve body on the newer models. Replacement may happen, but the trans may still die and they won't cover it.
Old 05-25-2011, 08:35 PM
2004NBTURBOS's Avatar
Peace Love & T.o.D.
Ocean View, DE, USA
Car: 1st 2000 GLX now 03.5 TS
Originally Posted by Smileybug View Post
The auto in those cars is the O1M, which is junk..
Peace Love an T.o.D.
Old 05-26-2011, 03:37 AM
JP's Avatar
JPRegistered Member JP is offline
Cortlandt Manor, NY, USA
Car: 2001 VW Beetle GL 2.slow
well i have the infamous 01m transmission let me tell you it ain't no walk in the park, i got this nb from my cousin he bought it new from the stealership at 8000 miles the original transmission went it was replaced with a new one, now in 2011 i have it at 117000+ Miles and i changed the fluid about six months ago but this thing has a mind of it's own if your going up a hill and you don't give it enough gas it will buck you have to drive it like you were Richard petty on the racetrack, the gearing in it suck's it shift's too early like a noob when they first learn to drive stick and it takes it's time shifting into reverse (like 3-5 seconds) sound like a stick but it's automatic 4-speed. just to let you know if you get one i found a ebay store that sells automatic transmissions new for like 1300 bucks
Old 05-28-2011, 03:29 AM
deenalouise's Avatar
Bellingham, WA, USA
Car: 2005 2.0 convertible
There might be a reason the car has low miles- just saying if the transmission is bad you can't put the miles on. Sounds like you want the car regardless of what folks say, so if you want to buy it- buy it. I've had my manual for 1.5 years, 72,000ish miles and runs like a charm
10 Cars That'll Look Good in 10 Years Abbie2007Beetle Miscellaneous Hoo-Ha 8 03-29-2011 06:29 PM
WTB: BAD Auto TDi trans... beetlecupkid Parts and Accessories 7 08-03-2008 09:00 PM
Help Auto Trans :( kewl_guy33 Transmission Talk 2 03-11-2008 07:14 AM
Will a 2003 New Beetle 2.0l auto trans work in a 1998 new beetle 2.0l auto? SLC Dubster Transmission Talk 4 10-01-2007 03:17 AM
