:confused: 01 Secondary shift solenid - NewBeetle.org Forums
Old 05-27-2011, 05:38 AM
Missladylinda's Avatar
Arlington, WA, USA
Car: 2001 Techno Blue Beetle 1.8T
Default :confused: 01 Secondary shift solenid
I been looking for this part,I was told this is whats causing my problems..So how much is this part? Cant seem to find 1. Also where does this part go inside? or outside of the trans.
Can't sleep cuz the Beetle's are after me!
Old 05-27-2011, 02:42 PM
mltRegistered Member mlt is offline
St. Paul, MN, USA
Car: 2002 GLS 2.0L auto
It depends what solenoid you are talking about. Some of them (valves that actually cause to change gears on automatic transmission) are inside. Here are some pics of various transmission internals to get an idea the 096/01m internal harness DIY...enjoy! VWVortex.com - Solenoid Change 09A Tiptronic
Old 05-31-2011, 09:23 PM
Arlington, WA, USA
Sooooooo i been trying to figure out my troubles with no real help..Now was told the Autozone scan tool maybe not telling me everything..
So heres what happened..
Last week noticed when i put it in Park from drive.Boo would freely roll a bit..Noticed bout 3 times
Day it happened he was finde til i stopped at a light..had to push down hard to get him to move(Limp Mode) noticed a tiny drop on RPM's
Brakes seemed mushy & Steering (loss of air pressure?)
Also after checking air filter a plastic rib looking hose broke,not fitting right.Whistling loud til i push on end then fine,so i need this hose replaced..
the 2 things that came up on Autozone Scan
secondary air pump & secondary shift solenoid..HELP anyone??
Old 05-31-2011, 10:27 PM
What were the actual codes that were pulled (should be in a pxxxx form). That might help us help you.
Old 06-01-2011, 05:23 AM
Arlington, WA, USA
1 i got today was P7068
Old 06-10-2011, 11:04 PM
Arlington, WA, USA
SOOO i'm having serious doubts this fix on my 01M will be worth it so,I need some help in finding how to go about a 5sp change on Boo..If anyone could like pinpoint the cost for me that would be awesome..I'm limited internet use,since i have no internet at home and had to pawn my laptop.(i get 2 hrs max a day) Library..And i think in the long run it be best..So any help would be great..I live North of Seattle so you will know more the area to search parts
Like will new 5 sp better then used etc..
HELP???
I'm confused.... fbodgrl 2.0 Liter Gas 8 05-24-2011 04:05 PM
I'm really just confused! AddToChaos 1.8 Liter Turbo 69 01-12-2011 09:04 AM
I'm confused Boopster Suggestion Box 6 08-28-2008 07:51 PM
New to VW- and confused all the way.. AutumnAsh Technical Modifications 1 04-03-2008 08:57 PM
How to install a shift knob/shift boot denisse 2.0 Liter Gas 1 03-16-2007 02:17 PM
