Inspection error? - NewBeetle.org Forums
Old 06-08-2011, 06:07 AM
Fox's Avatar
FoxRegistered Member Fox is offline
Los Angeles, CA, USA
Question Inspection error?
I'm looking at purchasing a automatic 2002 Silver NB with... 130,000 miles on it! It drives great (like verrry smooth, better than the other 4 NBs I test-drove), seems to have been well taken care of, no major repairs done on the carfax...
I took it in today to get inspected, and the only 'major' thing that popped up was this (taken word for word from the sheet, because I don't know much about engines and that sort of stuff ): "Sporadic Transmission Fault - Torque Converter Lockup". Now the mechanic was telling me that this intermittent error could be 'cleared' and might just be a faulty 'speed sensor,' I think? Or that it could mean problems for the transmission... really he just said, "You could drive for thousands of miles and have no problem... or the transmission could go out in two weeks, I don't know"... it was really strange, basically it sounded like he really didn't know whether it was serious or not?
I wondered if anyone else had seen this 'error' before and might be able to shed a little more light? Is it really as ambiguous as he was leading me to believe, or does this either A) Not really mean anything or B) Mean the transmission will have to be replaced soon?! Or something else? ...I don't want to buy a car and then have to spend the same amount buying a new transmission for it xp The fact that it's 'sporadic' has me really wondering whether I should really be too worried... I don't know!
Last edited by Fox; 06-08-2011 at 06:10 AM.. Reason: Just clarifying a small detail
Old 06-08-2011, 12:31 PM
MyOtherRidesAVette's Avatar
Question
Buying any vehicle with 130k miles, anything could go at any time. If the mechanic could predict what and when something is going to happen, he could make a much better living than being a mechanic, and he would actually be quite a phenomenon. Don't know about the stored code issue, but it would appear he is being totally honest with you.
MORAV
In der Automobil-Scheune
Old 06-08-2011, 02:40 PM
I would imagine that means he pulled codes on the car. Do you know what the actual code was? (Pxxxx code). Some code readers interpret VW codes incorrectly or in too vague of a way. If we know the actual P code, we can probably help see what it actually means for you.
Need n.h. Inspection & cel light is on! giink 2.0 Liter Gas 21 01-06-2011 02:51 PM
timing belt inspection rgar98 1.8 Liter Turbo 10 02-10-2010 03:09 AM
inspection question mrsbeazley Miscellaneous Hoo-Ha 1 05-01-2009 12:08 PM
CEL, Airbag and State Inspection jbthompson Questions, Issues, Concerns, or Problems with the New Beetle 2 12-09-2006 12:30 AM
