98 Shifter box/assembly/cables upgradeable to 2000+ assembly? - NewBeetle.org Forums
Old 09-13-2011, 08:55 AM
santa rosa, CA,
Car: 98 NB
Default 98 Shifter box/assembly/cables upgradeable to 2000+ assembly?
I have a 98 NB that is having some shifter problems, can't shift into 1st/reverse. I have already replaced the plastic part that always breaks. that fixed it a bit. However it still doesn't really work. I tried adjusting the shifter cable but that also only slightly helps.
I think the main problem is with my shifter box/floor assembly. Im going to try to replace the whole thing since i can't seem to find anything through the 33 pages in the transmission forum and 150+ in the technical forums either.
So my main question is. Can i replace the assembly with a newer non-frankenstein mix up from a 2000+ NB? Any help would be greatly appreciated it. Or any other suggestions to try.
Side note. my shifter seems to be only have ride side play in neutral. You can't shake the whole shifter left to right like normal. its like the shifter is just stuck to the left side. I feel like this is probably the cause of the issue.
Old 09-13-2011, 11:20 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
To change the shifter box, you have to change the shift tower in the transmission. Not a hard job to do at all, but finding parts can be a challenge. Look for transmissions with damaged cases that are for parts only.
If you want more info, let me know and I will get you more details.
Sent from my DROID2
2000 New Beetle GLS TDI
Old 10-07-2011, 11:47 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
I read on this site about a year or so ago; there is a plastic ring in the floor shifter housing that breaks and it then interferes with shifting; have you taken apart the floor housing to check it?
I was going to change mine but never got around to it and forgot.
My NB Family...
WTB Shifter assembly for 98 NB Cooky Parts and Accessories 1 04-13-2010 11:50 AM
WTB // Shifter & Cables off a 98-99 TDI ramprat Parts and Accessories 0 01-01-2010 03:54 AM
WTB shifter & boot assembly dsaldiv5 Parts and Accessories 0 10-31-2009 02:59 PM
WTB: Drivers-side door latch assembly for 2000 NB ChuckDubDub Parts and Accessories 0 06-13-2009 07:54 PM
audi tt shifter assembly Nb2Nv Styling Modifications 0 11-19-2006 11:40 PM
