6 speed clutch bleeding problems? - NewBeetle.org Forums
Old 10-16-2011, 12:06 AM
slartibartfast's Avatar
NC, USA
Car: 03 turbo s bug
Default 6 speed clutch bleeding problems?
So pretty much like it says. I did a clutch in my 03 Beetle turbo s and now i am having a hard time getting the clutch to bleed. If anybody has any suggestions please let me know thanks.
Old 10-16-2011, 07:14 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
I do not have a Turbo S; however when you bleed it, what does it do?
All mine (APH-O2J) did was gurgle and spit and very little came out even after changing the Master and Slave Cylinder. I am in the process of changing my clutch too.
My NB Family...
Old 10-16-2011, 07:56 PM
NC, USA
Car: 03 turbo s bug
My pedal goes to the floor and stays, no noise no gurgling no nothing. Im thinking of replacing the master, even though I replaced it five months ago, but thats what you get for buying cheep auto zone junk. I should have spent the extra twenty dollars for the factory part. Lesson learned.
Old 10-16-2011, 09:54 PM
Tioga, TX, USA
Car: NB 2000 TDI
Sounds like you introduced a bunch of air into the system. Fill the master cylinder with fluid and try bumping the clutch pedal several times. You are not trying to push the fluid thru, just trying to get rid of the suspected air bubble in the line. by barely bumping the pedal you are not compressing the air just allowing a little at a time to bubble back up thru the master cyl. Give it a try I do it all the time when i do brakes and such. you can acutally bleed the system just bey doing this.
:: ECS Tuning :: ECS 6-Speed Clutch Bleeder Block - Now Available !!! ECS Tuning Transmission Talk 2 09-02-2011 01:45 PM
FS: 6 Speed OEM Clutch FallinApartBoy Parts and Accessories 0 04-15-2009 02:40 PM
anyone done a 6 speed clutch? FallinApartBoy Transmission Talk 4 03-11-2009 04:31 PM
Clutch Bleeding, this is weird... Ziggi 1.8 Liter Turbo 9 08-25-2007 06:12 PM
New Tiptronic Tranny: 7 Speed Double Clutch Moviequill Transmission Talk 1 07-27-2006 02:32 PM
