The end of the shifter cable on my 1998 2.0 5 speed has broken in half. This is the lower cable end that attaches to the "golf club". It appears to be a cast metal piece. Is their a cable end replacement that can be fitted? or does the cable assembly have to be replaced...and if so, how difficult is this?
Home Page > Search > Short Shift > ES#648 TT Short Shift Kit - With Shifter Cable End - 8N0711046 ECS tuning sells it for $39.95 but never has it in stock. VWOEMPARTSONLINE.COM sells it for $43.xx bucks and they always have it in stock. The TT unit also reduces shifter throw by about 20% which makes it an OEM short shifter. Feels great and shifts even better. Also those cable ends are about 23 bucks a piece in case you don't want to swap out the shifter itself. http://www.ecstuning.com/Search/Cable_End/ES7056/ So don't let a dealer rip you off and charge you hundreds of dollars to replace a fairly inexpensive part that you can do yourself in about 15-20 minutes. Last edited by IndyTom; 10-27-2011 at 03:31 AM.. |
with the newer and improved "Square tip" design Home Page > Search > Cable End > ES#7056 Shifter Cable End - 1J0711761B Those should last longer and give you a more positive shift feel. If you got charged hundreds of dollars to replace that shift linkage assembly you have been taken to the cleaners. Even the dealer price for the shifter assy plus two new cable ends shouldn't been more than 85 bucks tops. Plus labor which I know they charge a lot but even with them working at snail speed they could have done that job in about 30 minutes. So if you got charged more than $150.00 bucks total you paid too much. |
Standard Definition Video: MKIV Short Shift Bracket Install |
Mine really didn't break. I just thought it would be cool to get the TT short shift cable bracket. It does seem to reduce throw a bit. Quicker shifts and not notchy like some other short shift kits since this is OEM. Less agressive but it works.
You get the part at the dealer because they stock it and it is under $50. Not too in depth for the repair. Here is the link. Shift Carrier Lever DIY ![]() |
| wtb shifter cable | dirtyleft | Parts and Accessories | 1 | 06-27-2010 04:12 PM |
| Shifter cable bushings!!! | AbuNigel | Technical Modifications | 0 | 05-29-2010 11:22 AM |
| PS re broken shift cable on 1999 New Beetle | GaryGary | New Member Forum | 0 | 04-11-2009 08:24 PM |
| Question re broken shift cable on 1999 New Beetle | GaryGary | New Member Forum | 0 | 04-11-2009 08:21 PM |
| 1998 VW Beetle Throttle Cable? | WhatTheVDub | 2.0 Liter Gas | 1 | 07-06-2008 01:30 PM |
