| LinkBack | Thread Tools | Display Modes |
Hi guys! so flushing is not really advisable? ok if thats the case then this tuesday I will let them drain it and change filter and fluid just to be sure. it's better if I could also talk to the mechanic in person so that I could hear his technical reason for the flushing and then we go from there.
About the water pump..yup! they did not change it because it is not part of the warranty and not included in the general 100k mntainance here in NZ I think ![]() |
Hi! You also got a point thr. At this stage the last say or decision would be from the mechanic
I still on doubt if they did not change the water pump since it was a long the way when changing the timing belt as you guys said. It will be confirmed next week when I meet him. Maybe the secretary whom I speak to after I talk to the mechanic don't have an idea what was change etc. As long as they will treat my bug accordingly then there would be no problem ![]() |
I have no clue on the procedure for the NB, but I know on my husband's Honda Accord, the fluid change procedure for his transmission calls for you to drain and fill 3 times. After each fill, run the car through all of the gears to get the fluid moving around, then drain. Doing this 3 times gets a better chance of getting all of the bad stuff out (and you do see the fluid getting cleaner each time. We do this ourselves). But with needing to use VAG-COM for checking the level properly, not sure if its that easy with the NB. There is a dipstick on the Honda trans and all very, very easy to do.
at last trans fluid change already done yesterday and so far it only jerks twice today..cause befor wen i place the gear to drive..wont move..now, it moves without stepping the gas..is this a got sign of recovery?
I hate to say this but there is no magic fix for an Automatic Transmission once it is acting up. Your Valve Body is what is causing the jerking and perhaps the new fluid did clear one or more blockages but that is only temporary. Once the valve body goes the transmission isn't far behind. I do wish you good luck and hope you can enjoy driving it for a few months longer.
so if it was'nt fix by a transmission fluid change so there must be a bigger problem? i don't mind if the transmission goes anytime this year because I have a 2 year mechanical warranty. But beyond that, I maybe in trouble financially
![]() They already fix/change my power window, leak engine oil and power steering with no cost on my side. |
It's a well documented case that the Valve body in the early model Beetle's is weak and breaks down. This will reduce line pressure to the transmission itself and eventually burn out the clutches. So in other words once the Valve body fails completely the transmission will be toast as well. Dealership charges about 1500-2000 for a new valve body. A rebuilt transmission will be a lot higher in price. I would keep complaining until the fix the valve body or better yet replace the transmission. Because it isn't if it will fail but when. |
Yup I would and keep my eye on my bug for ther maybe more unexplained problems coming. But today I am lucky that no jerking happened. I'll keep you guys posted in a months time on this. I also found out that my secondary air pump is noisy when active like a jet plane and when I put my hand close to it I feel air coming out were the pump and the tube is connected. My secondary pump is dfrent from others I saw here in org. It has no revits. Can I fix this on my own or need to bring it to the shop again?
thanks again guys! |
If I can fix it like what i read on the org. which is cheap and easy I would rather than taking a day off just to drive my car to the shop, rent a replacement car and taking a day off again to get the car..whew!! even though it never cost me money to fix it but the hassle sometimes is not worth it and gets us frustrated..
Indytom just opened my engine cover and found out that the tube lines were the air leeks is not totally place properly in the SAP and loose. When I push it in, it click and locked. Now it wont make a jet engine sound no more!! yepey..thanks org!! Last edited by Beetle_NZ; 01-23-2012 at 05:25 PM.. |
I had the delay into D and R. Sometimes even a low speed stall and harsh gear engagement. Went to the dealership, spent $300 to have it serviced, and the problem is gone! Funny thing is, there was no oil leak on the trans, no computer error codes, 57,000 mile car, and the service department had nothing to say. I dont have the proper tools or the time to do the job, so the $150+ in labor, was well worth it!
I'm not a First Gear Jerk. I love ALL gears!
Former VWs: 2002 NB Turbo S - Platinum Gray 2003 NB TDI - Galactic Blue 2005 NBC 1.8T- Tornado Red 2006 Passat 2.0T- Blue Graphite 2003 NB Turbo S - UniRed 2005 V6 Touareg V6 - Campanella White Currently: 2002 NB GLX 1.8T - White Paint |
| Car Hesitates and Jerks | nancyannenj | New Beetle Convertible | 1 | 11-28-2011 03:44 PM |
| The world is full of jerks. | Fallon | Miscellaneous Hoo-Ha | 30 | 08-21-2011 04:13 AM |
| Won't go into R, 5th or 1st gear | kel | Transmission Talk | 5 | 08-13-2011 04:13 PM |
| Help! Car won't go into gear!!!!! | Blitz Kafer | 1.8 Liter Turbo | 22 | 05-01-2010 07:11 AM |
| 5th gear mod? | sean_fabanich | Transmission Talk | 3 | 04-10-2010 04:03 AM |
