2001 automatic shift problems - NewBeetle.org Forums
Old 12-15-2011, 12:43 AM
JamieClay's Avatar
CA,
Car: 2001 Automatic
Default 2001 automatic shift problems
I've recently acquired a 2001 and it has some interesting transmission problems I'm hoping someone else has run into.
1) When cold it shifts normally
2) Once warmed up it is prone to shifting failures
- longer than normal slides between shifts
- failure to fully engage 4th gear
- sudden and harsh shift (this is very infrequent)
3) I've changed the fluid to examine it and as a matter of course, it looked great, didn't smell burned, very little detritus in the pan, no metal filings.
4) I've gotten the P0740 code that according to the Bentley manual is "Torque Converter Clutch Circuit Malfunction".
5) If when the car won't go into 4th, I shift it into 3rd it engages right away.
In taking it to mechanics - both have said they need to replace the transmission, no other technical details. So to hell with them.
I'm thinking it's some sensor or valve.
Has anyone else run into this and found a solution other than replacing the transmission?
Thanks
Old 12-15-2011, 12:56 AM
Linden, MI, USA
Car: 1998 2.0L Auto Beetle
This website has a lot of information that may help. I learned quite a bit when working on my daughter's car.
Kansas City Tdi & CoolAirVw Repair
Old 12-15-2011, 01:12 AM
Look into the valve body. Lots of discussion on here about it. Very prone to failure.
Old 12-15-2011, 03:41 AM
IndyTom's Avatar
Indianapolis, IN, USA
I second that. Those harsh shifts are from a failing valve body. Those things are known to go out on those already crappy auto transmissions. Average price to replace at the dealer around $1700.xx
Tags
automatic , problems , shift
Automatic Transmission Problems 98beetlebug 2.0 Liter Gas 10 10-26-2011 06:23 PM
F/S automatic shift plate in black. beej Parts and Accessories 0 07-19-2009 07:56 PM
WTB: Automatic Shift Plate SMG Parts and Accessories 2 01-28-2009 04:40 PM
Automatic Shift Knob Black piece? TechnoBug88 Technical Modifications 3 07-31-2008 02:51 PM
Automatic Shift Illumination Dead titonee35 2.0 Liter Gas 0 09-11-2007 11:39 PM
