Alright those around here know me and know that I stay away from the dreaded O1M at all costs, but we found an '01 TDI Jetta with 114k with a potentially dead one for a crazy price so we jumped on it. We do have a manual swap donor car available to us for cheap as well so that will be happening if this trans is actually toast but if its not, then we have no problems driving it for a bit if we can fix it without much effort.
Got a number of codes. Story is the guy we got it from got it from a cousin. You can shift into drive, 3, 2, 1, N, etc with no problems, but the car will just rev and not move. Seems like its stuck in neutral. But the car won't move backwards in neutral (park seems to work). Transmission error codes: 00652 00652 - Ross-Tech Wiki 00652 - Gear Monitoring: Implausible Signal Possible Causes Automatic Transmission Fluid (ATF) Level not OK Vehicle Speed Sensor (G68) dirty/faulty o Impulse Wheel dirty or Installation faulty Gearbox Speed Sensor (G38) dirty/faulty o Impulse Wheel dirty or Installation faulty Multi-Function Switch (F125) faulty (but not detected) Clutch or Valve Body faulty Automatic Transmission Fluid (ATF) Pump faulty Possible Solutions Check Automatic Transmission Fluid (ATF) Level Check/Clean/Replace Vehicle Speed Sensor (G68) Check/Clean/Replace Gearbox Speed Sensor (G38) Check/Replace Multi-Function Switch (F125) Check/Replace Clutch and/or Valve Body Special Notes The ratio of engine speed to gearbox output speed in the currently engaged gear is implausible. Slip rpm with torque converter lock-up clutch disengaged must be greater than stall speed. ------------------------------------------------ 00300 00300 - Ross-Tech Wiki 00300 - Transmission Fluid Temp. Sensor (G93) - Implausible Signal Possible Symptoms MIL On Transmission Not Shifting Properly or in Limp Mode \ Possible Causes Wiring/Connectors from/to Transmission Fluid Temp. Sensor (G93) faulty Voltage Supply for Transmission Fluid Temp. Sensor (G93) faulty Transmission Fluid Temp. Sensor (G93) faulty Possible Solutions Check Wiring/Connectors from/to Transmission Fluid Temp. Sensor (G93) Check Voltage Supply for Transmission Fluid Temp. Sensor (G93) Check Measuring Blocks for Transmission Fluid Temp. Sensor (G93) Readings Check / Replace Transmission Fluid Temp. Sensor (G93) -------------------------------------------------------- 01192 01192 - Ross-Tech Wiki 01192 - Torque Converter Lock-Up Clutch 01192 - Torque Converter Lock-Up Clutch: Mechanical Malfunction Possible Symptoms Torque Converter Lock-Up Clutch slipping Possible Causes Torque Converter Lock-Up Clutch faulty Valve Body faulty Internal Failure in Transmission Possible Solutions Check Torque Converter Lock-Up Clutch Slip Special Notes When found in 4-Speed Automatic Transmission (01M), check Measuring Value Block (MVB) 007. ---------------------------- We do have VAG-COM. Need to check out that measuring block. We did get a number of codes of short to ground and other electrical issues. Any chance that there could be something wiring wise causing all of these? Stuck in neutral seems like an odd failure, almost like a sensor isn't working right. We are fully prepared too if it ends up being that the trans is just crapped out. Again, we have all the stuff needed for a swap to a 5-speed. But hey, if we could get the auto working again, we'd be all for that until it does finally die. 114k seems a bit early for death, but its a TDI so who knows. Good news is the rest of the car is in fantastic shape and the engine sounds very healthy. A timing belt job is in the future probably, but we'll inspect as well. Will also try clearing the codes and see if it does anything. maybe a fluid and filter change is in order too. To start we'll be tracking down electrical I think. I know this isn't the most technical of forums...we'll likely end up in the auto section of Vortex but I figured here would be a good place to ask too.
The Baby: Darla, 102k, '99 New Beetle GL 5-speed. Bone stock. Acquired 4/6/05. Gave her life for me 8/17/11. RIP ![]() The Project: Klaus, 180k+, '84 Jetta GL Turbo Diesel. Rebuilt and bringing 50+ mpg. Slightly improved from stock Acquired 7/12/08The Baby Brother: Gόnther, 20th Anniversary Edition GTI ![]() The money saver:2001 Jetta TDI GL. 114k. Dead auto, swapped to 3 pedals. Hubby's DD and our trip car |
Automatics are not my thing, but if it were me I would change the ATF and the Gear Oil; then the following sensors, G68, then G38, then G93 and then F125.
Just my .02 ...
My NB Family... |
Yeah I don't know how far we're going to get in to trying to fix it if its much over some stupid wiring or an easy sensor. We have a 5-speed donor ready to go so its not a huge deal, and we don't really want to drive the auto. But hey, if we could get it working with little cost then we will.
Cleared the codes last night. Battery isn't strong enough to get her to turn over so we need a charger. After we get that (wednesday) we'll start her up and see if anything has changed. |
| What should I do with my dead Bug? | iScott | Questions, Issues, Concerns, or Problems with the New Beetle | 28 | 12-24-2011 02:27 AM |
| Dead ECU | doitwisely | 2.0 Liter Gas | 10 | 01-19-2011 01:24 AM |
| Will a 2003 New Beetle 2.0l auto trans work in a 1998 new beetle 2.0l auto? | SLC Dubster | Transmission Talk | 4 | 10-01-2007 03:17 AM |
| My car is dead...again | dasmurph | The New Beetle Experience | 47 | 03-21-2007 10:24 PM |
| My Bug is Dead. Help! | Lime Green Bug | Questions, Issues, Concerns, or Problems with the New Beetle | 11 | 01-22-2007 09:23 AM |
