Looking to replace my 2005 New Beetle transmission valve body and was wondering the sequesnce of events after I install the replacement? I'm going to assume that I would have to go into the TCU/M with a Vagcom and reset transmission? Has anyone done this before, would love to hear the in's / out's of the process- thanks in advance!
V/r Joe |
Yes it's best to reset your transmission. Use VAG-COM, go to transmission module, then Adaption(10), select 001(as I remember), then it will tell you that it's going to reset the TCM. Then confirm will be fine. |
This may sound really silly, but please keep in mind I don't knokw a lot about cars...does this work if you don't replace anything that they find faulty? They say there's a problem but they don't know what it is. I thought valve body (see my most recent post). Do you think if it is just reset it might be back to normal?
Won't work if you don't do any work. Generally transmission computer reset has to be done if you replaced valve body to let the computer learn the parameters of your new valve body and clear the parameters of the old one. I've heard someone's trans in limp mode he reset the trans it went back good for a short time and then limp again. Generally if there's a transmission problem you need to cure the problem, either mechanical or electrical. If you don't do any work about the problem it won't cure itself. |
Falcone or Tom Wood. Personally, I never liked Tom Wood. Actually, since you are in Indianapolis take it to EPWerks! They are a Fantastic VW/Audi shop that does excellent work for a fraction of what the dealer will charge. http://www.epwerks.com/ Call either Ian or Kevin and they will take good care of you. Last edited by IndyTom; 02-22-2012 at 09:59 PM.. |
| 2.5L PCV valve, valve cover replacement questions | PTL5spd | 2.5 Liter Gas | 2 | 09-03-2011 11:27 PM |
| new beetle valve body 09g $550 | vanagonman | New Beetle Classifieds | 0 | 03-17-2011 12:25 AM |
| Valve body/Triptronic? | BeetleLinz1125 | 1.8 Liter Turbo | 3 | 03-07-2011 01:59 PM |
| Changing valve body | Chris333 | Transmission Talk | 0 | 12-12-2007 08:08 AM |
