I've got a question... - NewBeetle.org Forums
Old 02-12-2012, 12:11 AM
Bratgirl's Avatar
Powered By Pixie Dust
Riverton, UT, USA
Car: 2002 Yellow GLS
Default I've got a question...
I was playing around with the decoder page that tells you what all those numbers on the sticker in the trunk mean. I found something weird..I thought my car was a 4 speed auto, but this says it is a 5 speed auto.(see below)
Weren't all the 5 speeds the tiptronic style? Mine is not of course, or I would not be asking this probably silly question.
Barb
X9A = National sales program USA
CA9 = Alloy wheels 6.5J x 16
G0F = 5-speed automatic transmission
H4B = All-weather tires 205/55 R16 H (NAR)
J1L = Battery 280 A (60 Ah)
K8F = Roundback
4UB = Air bag for NAR
ML5 = 4-cylinder gasoline engine 2.0 L/85 kW multi-point injection, LEV/ULEV base engine is T52/TB8
U0N = Instrument insert with mph speedometer, tachometer, trip odometer
V0L = GOODYEAR tires
0A1 = 2 doors
0N5 = Standard rear axle
1C2 = Antifreeze up to -35 degree celsius tolerance up to -40 degree C
1G2 = Steel spare wheel with original equipment tires
1H0 = Without proportioning valve
1MF = Comfort steering wheel for air bag system
2JG = Body-colored bumpers
5RR = Right exterior mirror: convex (US)
5SH = Left exterior mirror: flat (US)
0CU = Vehicle class differentiation 1C0
4X5 = Side air bag, front (NAR) (out of position)
0GM = Emission standard LEV 1
3L3 = Manual height adjustment for front seats
3Q1 = Rear headrests
QG0 = Without service interval prolongation
89T = code not found :-(
B0W = Component parts set, complying with vehicle type for California, various parts
1NQ = Full wheel covers
3FE = Electric slide/tilt sunroof with sun screen/sunblind
4K0 = Radio remote controlled central locking operated from inside
4RH = One 3-point seat belts and one lap belt with retractor in second row of seats
9AB = Manually controlled air conditioning
Live a Life of Serenity, Not a Life of Regret.
Current NB 2002 GLS Double Yellow "Pixie"
Previous NB 2000 GLX Black "Little Ed"
"Other" Road Trippin' Ride
2010 Dodge Challenger Bright White "Baby"
Old 02-12-2012, 01:01 AM
IndyTom's Avatar
Indianapolis, IN, USA
They only made the O1M 4 Speed Automatic until 2002. Then sometime in 2002 they did switch to the 09A 5sp Tiptronic transmission Years used: 2002, 2003, 2004.
So Yes, you should have a 09A transmission code 5 Speed tiptronic.
Old 02-12-2012, 01:13 AM
Bratgirl's Avatar
Riverton, UT, USA
But it doesn't is what's weird. No + or - on the shift console or room to move the shifter. What is up with that?
The second picture in this thread shows my console and shifter..
Some pictures..
Old 02-12-2012, 01:50 AM
IndyTom's Avatar
Hmm, Perhaps you have very tiny Paddle shifters hidden behind your steering wheel
Or perhaps the sticker in your trunk is wrong? I couldn't find where the cut off was for the O1M 4speed Automatic. I know it was in 2002. After that they came out with the 09A 5 speed triptronic which was put in cars until 2004. 2005 was the first year for the 6 speed tiptronic. However, I think some convertibles already had them in 2004.5
Old 02-12-2012, 02:19 AM
Bratgirl's Avatar
Riverton, UT, USA
Very very tiny invisible paddles...lol. The sticker looks like it has been in there for quite a while, but who knows if it is the right one. I couldn't find anything on the cut off dates either. She was built on April 10th of 2002. Very weird.. I dropped her off yesterday at my friends transmission shop to get the fluids changed, so when I pick her up Monday, I will ask Rick what it is. Is there some kind of number or markings on the trans itself that will tell you what it is?
Old 02-12-2012, 04:25 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
This Thread might be helpful ...
My NB Family...
Old 02-12-2012, 06:28 PM
IndyTom's Avatar
Hmm, not really since it doesn't show her sub code in any of them G0F?? It also doesn't show the sub codes for the 09A transmission which she might have??
You can check with your mechanic since the tiptronic transmissions have the valvebodies one the side rather than on the bottom of the transmissions. I guess the mystery remains.
Let me go check my Bentley manual...
I'll be back
Old 02-12-2012, 06:56 PM
IndyTom's Avatar
Well, the Bentley tells me that there were only 2 automatic transmissions not counting the DSG (02E) that was only used on the TDI models.
It shows the 01M 4 speed 1998-2005
and the 09G 6 speed 2003- on.
The sub code letters for the 01M were:
DYQ,ECV,ELY,EPG,FDF - 2.0L
EFB,ECP,ELU,ELZ,EPC,EPH,FDC,FDG - 1.8L AND 2.0L
DMP,ECN,ELT,EPB,EPP,FDB - 1.9L
The sub code letters for the 09G were:
GHE,HGA,HHT -1.8L
GGZ,HFZ,HMD -2.0L
HHG,HTU -2.5L
No mentioning whatsoever of any 5 speed automatic transmission.
Only the DSG, the 4 Speed and the 6 speed Autos.
So my guess is that you do have the 01M transmission. It does hold 5.3 liter of transmission fluid and does have a seperate final drive which takes .75liters of 75W90 Synthetic gear lube.
Make sure your mechanic doesn't miss that.
The 6 Speed tiptronic uses 7.3 liter of fluid and combines the transmission and final drive. Meaning it doesn't have a seperate final drive fluid.
Hope that helps shed some light on the situation.
Old 02-12-2012, 08:40 PM
Bratgirl's Avatar
Riverton, UT, USA
I found the paper I had written all those numbers on to enter them in the decoder..the first numbers I had written down were these..
ICI8H3
AVH FDF
LD1D LJ
So there is the "sub-code" FDF for the O1M trans. But there is also that G0F code for the 5 speed auto.
How bizzare..
In reference to the seperate trans and final drive, a while back I took DaZee to my mechanic to have them change the differential fluid and they told me they could not do it because the diff and trans were all in one case, so they told me I should take it to a transmission shop. That is why I took it to Rick to have it done.
So is it two seperate deals contained in the same case with a seal or whatever between the two to keep the 2 kinds of fluid seperated ( I think I read that on here somewhere) , or is it all together and shares the same fluid?
I am really confused now. lol
Old 02-12-2012, 10:49 PM
D2Beetle's Avatar
NB Yellow Trifecta
The plot thickens ... to know for sure, look on the top of the transmission, just below the radiator hose and you will find out for a certainty.
Old 02-12-2012, 11:17 PM
Bratgirl's Avatar
Riverton, UT, USA
I will have to look at that when I pick her up from Rick tomorrow. He can probably just tell me what it is.
Sent from my SCH-I510 using Tapatalk
Old 02-13-2012, 01:09 AM
IndyTom's Avatar
ICI8H3
AVH FDF
LD1D LJ
How bizzare..
The ATF fluid and the gear differential fluid are seperate on the 01M transmission. They are not mixed and are two different kind of fluids. According to Bentley the ATF fluid is VW Part number G 052 162 A2 and the capacity is 5.3 Liters or 5.6 quarts. However when you change the fluid you can only get in about 3Liters or 3.2Quarts. The differential takes VW Part number G 052 145 A2 and holds .75 Liters or .8 Quarts. VW deems it to be lifetime so they don't show a change interval for the rear differential.
Old 02-13-2012, 02:17 AM
Bratgirl's Avatar
Riverton, UT, USA
That is how I thought it was too. Guess I will find out more tomorrow.
Curiouser and curiouser
Old 02-15-2012, 02:47 PM
Bratgirl's Avatar
Riverton, UT, USA
Well, tomorrow turned into another tomorrow and finally yesterday I got to pick up my girl. I still haven't had time to look at the actual trans plate, (it was dark by the time I got home, I will look this afternoon after work), but I talked to Rick the trans guy, and he said my transmission is absolutely an O1M (4 speed) model. So, why it has that funky code is anybodys guess. Unless it was originally slated to be a 5 speed tip on the assembly line, and a customer state side wanted a Double Yellow NOW and no tiptronic, so they just threw a 4 speed in to get it shipped and delivered.
Anyway, she has new fluid in the trans and diff and is happily buzzing along.
Old 02-15-2012, 09:11 PM
D2Beetle's Avatar
NB Yellow Trifecta
Transmissions have two 3 digit codes O1M (Primary) and a ??? (Secondary). It is the second code that denotes the gearing. I am really curious what your second code is.
Here is the Thread noting the Transmission Codes for my NB's.
Old 02-15-2012, 09:21 PM
IndyTom's Avatar
Her Subcode is FDF
pcv valve question and oil question a_magoo 1.8 Liter Turbo 3 10-07-2006 01:31 AM
p 0411 code question and coolant leak question.... bobbittle 1.8 Liter Turbo 5 06-12-2006 02:47 PM
