Changing transmission fluid 2.0 automatic - NewBeetle.org Forums
Go Back   NewBeetle.org Home > NewBeetle.org Forums > 1998-2011 New Beetle > Transmission Talk
Old 04-14-2012, 07:56 PM
Default Changing transmission fluid 2.0 automatic
Hello, I've been lurking since I purchased my g/f a used "new" beetle and have found this forum to be a huge wealth of knowledge and would like to first thank all contributors. Now for my question. I have a 2002 New Beetle 2.0 automatic. It has 141k on the original motor and tranny, I have recently noticed a 3-5 second delay while shifting her into drive from park. Is this normal???? Also I am noticing a hard down shift into first when she comes to a quick stop. Is there any remedy for this??? I am thinking of changing the transmission fluid and filter but am afraid this might make her shift even worse. It has just started to do this and I have noticed if I need to make an abrupt stop I throw it into neutral to avoid clunking into first. The guy at the parts desk at the VW dealer kinda threw me off when he said changing the fluid might make things worse off.... so any ideas? I am on the fence with what to do... I am thinking maybe check the level and add if it needs but if she is full then im back to square one...maybe throw a touch of lucas tranny fix to kinda keep it from down shifting so hard. Any thoughts or ideas would be greatly appreciated. I am going to check the level to make sure she isn't low...Thanks in advance any insight will be greatly appreciated.
Old 04-14-2012, 09:29 PM
IndyTom's Avatar
Indianapolis, IN, USA
Car: 2012 Tornado Red VW Beetle Tsi
You have the dreaded 01M Automatic transmission. The worst Transmission by VW ever made. They all do have weak valve bodies which fail and then eventually destroy the transmission. Changing out the valve body may help add a few more miles to the life of the transmission. Changing the fluid every 40k miles when it was new may have helped the life of the valve body but once it is that far gone only a replacement of the valve body will help unless the clutches in the transmission itself have already deteriorated in which case replacing the transmission would be needed.
You can try changing out the fluid and see if it helps a bit but I wouldn't count on it. I am attaching a PDF file for the proper procedure of changing fluid in a 01M transmission.
Good Luck!
Old 04-14-2012, 09:35 PM
IndyTom's Avatar
If you never ever changed the fluid in your 01M then that is your first mistake. That fluid isn't "Lifetime" as VW put in their manual. That stuff in there will be black as night by now and probably has destroyed the valve body. Changing the fluid won't make things worse. Whatever idiot told you that should be shot. Of course it may not help much especially if your valve body is shot. I would have the transmission flushed to get all the old crap out of there and refilled with all NEW transmission fluid. That should improve things for a while. If that doesn't work then I would get a rebuilt valve body. They run between 300-400 bucks. Well worth a shot.
Make sure whoever puts it in they do the Internal Link adjustment.
Good Luck!
Old 04-15-2012, 01:09 AM
IndyTom I don't know the first thing about the first thing, but for what you tell me....I am sure you are spot on after all I have been reading. I am terribly sorry about the double post if there is any way to delete I will. Thanks for the quick reply and being here for people such as myself. This will surly save old Betsy from the scrap yard and save me tons on letting the "pros" trouble shoot it for me. I am glad to know you are here. Thanks a million. I think it is early enough to save her, I will defiantly keep this thread posted on any follow ups and results.
Old 04-15-2012, 03:34 AM
IndyTom's Avatar
Don't worry about it. You can start with a fluid change and see how things go but at your mileage and your symptoms it definitely points to the valve body. I think you can get a decent rebuilt one for around 300-350 dollars.
Good Luck and I wish you lot of Happy times with Old Betsy
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Changing Auto Transmission Fluid - (How-To) -Discussion Thread marvins_dad Transmission Talk 29 03-04-2014 04:20 AM
changing transmission fluid a waste of time and money reflex7777 Transmission Talk 21 07-30-2011 03:26 PM
Automatic Trans. Fluid now 40,000 mi item 2.5 ltr with 09G transmission williamadamsesq Transmission Talk 3 05-08-2010 12:06 PM
timing belt and transmission fluid (automatic) cfromberg 1.8 Liter Turbo 9 12-02-2008 05:25 PM
