2001 1.8T Won't shift into 1st Gear - NewBeetle.org Forums
Old 01-16-2013, 11:07 PM
Default 2001 1.8T Won't shift into 1st Gear
Can't get the shifter to fully engage 1st gear. Pulled the air box to look around and can get all the gears to engage but it won't go all the way into 1st. Could this be a problem in the shifter area inside the car? Are there any known problems that would make it the transmission? How do you pull the cable ends off without breaking them? If I get the cable off I can check the trans arm without the shifter hooked up. This should tell me if it's the trans or not. Some input would be great. thx matt
Old 01-17-2013, 12:02 PM
Fairfax, VA, USA
Possibly a shift fork issue?
VWVortex.com - Have you broken a shift fork? (Poll)
What transmission & how many speed?
Old 01-17-2013, 01:34 PM
This is a 5-speed. The Turbo S is the only one with a 6-speed and that didn't start until 2002. I've not heard of shift fork problems in the 5-speeds, only the 6-speeds. The forum that's from is for cars that come with the 6-speed as well (GLI, 337, 20th).
Old 01-17-2013, 07:53 PM
IndyTom's Avatar
Indianapolis, IN, USA
Check out this video it shows you how to adjust the shifter.
VW 5 speed shifter adjustment for 02J and MQ250 transmissions - YouTube
Old 01-17-2013, 11:33 PM
Indy Tom,
Checked out the video and set the cable adjustment. All the gears work fine. The problem is that the Lever on the trans won't rotate all the way into the first gear detent. At the differnt heights for the different gears it works fine it just won't go all the way into first gear. Any Ideas? thx matt
Old 01-17-2013, 11:50 PM
Just saw a note somewhere about the 1-2 slider hub getting damaged by missing a gear. Could this be possible? matt
Hard to shift into 1st and 3rd gear. mrathell 2.0 Liter Gas 4 07-08-2010 11:47 AM
Hard to shift into 1st gear rooney77 1.9 Liter TDI 9 03-04-2009 10:11 AM
Removing Gear shift? PinkBug4289 Paint and Body 1 10-24-2008 02:03 AM
Shift/Gear Indicator BlueMax 1.8 Liter Turbo 3 01-04-2007 12:05 AM
Gear Shift Ivy Styling Modifications 6 04-27-2006 05:40 PM
