New Beetle Trans Gear Ratios - NewBeetle.org Forums
Old 05-17-2006, 06:12 PM
bugasm99's Avatar
OG Stalker
Philadelphia, PA, USA
Post New Beetle Trans Gear Ratios
I thought these might be useful at some point and rather then look around you can find them here.
"02J" 5 Speed New Beetle, Golf/Jetta IV
Code | 1st - 2nd - 3rd - 4th - 5th - R&P | Notes
CZM | 3.300 - 1.944 - 1.308 - 1.029 - 0.837 - 4.235 | 2.0L Beetle '98
DQY | 3.778 - 2.118 - 1.360 - 0.971 - 0.756 - 3.389 | TDI Beetle, Golf/Jetta IV
EGD | 3.300 - 1.944 - 1.308 - 1.029 - 0.837 - 3.938 | 1.8T Beetle '99
DZQ,EBP,EGT,EKG | 3.778 - 2.118 - 1.360 - 1.029 - 0.837 - 4.235 | 2.0L Beetle,Golf/Jetta IV
EBJ,EGR | 3.778 - 2.118 - 1.360 - 0.971 - 0.756 - 3.389 | TDI Beetle, Golf/Jetta IV
EBQ,EMT | 3.300 - 1.944 - 1.308 - 1.029 - 0.837 - 3.938 | 1.8T Beetle,Golf/Jetta IV
"01M" 4 Speed Automatic New Beetle, Golf, Jetta
DMP | 2.714 - 1.441 - 1.000 - 0.742 - 3.700 | TDI Beetle, Golf/Jetta
DYQ | 2.714 - 1.551 - 1.000 - 0.679 - 4.875 | 2.0L Beetle
ECP,EPC,EPL | 2.714 - 1.441 - 1.000 - 0.742 - 4.533 | 1.8T Beetle, Golf/Jetta IV
*This list was taken from Techtonics Website At www.techtonicstuning.com.
Old 10-05-2006, 04:47 AM
Bend, OR, USA
Car: 2004 Jetta TDI and 1998 NB
Yes, this is helpful. As I understand this, my final drive ratio in high gear on my 98 TDI (code DQY) is 2.562.
Then, with the EGD transmission, bolted up to the TDI and a .658 fifth from where ever it is the TDI guys are getting them this would give me a 2.591 final ratio.
This would give me low gearing for putt-putting around in the hills and trails, but it would leave my highway cruising right back near stock, so my mileage wouldn't take a hit on that end.
It looks like this is the only way to get back to that same final ratio, but there are other combinations available by swapping and mixing and matching. they would give different results that I would have to weigh individually. I saw someone linked to a calculator in the FAQs here, but the link is dead, apparently. If anyone knows where to find a good calculator for VWs that would be great.
Does this sound completely out of whack, or am I on the right track?
TDI No start troubleshooting.
Old 10-06-2006, 01:51 PM
Bend, OR, USA
Does anyone have any thoughts, snickers or pokes at my thought here?
Also does anyone know about gear swapability between different transmissions such as the 02J/02O/02M/??? ?
How to tell it's time for a new Trans. ? aefbug Transmission Talk 3 11-09-2006 04:16 AM
new car will not go in gear (auto trans. ) mikesbug New Member Forum 3 03-12-2006 03:06 PM
1.8 turbo auto trans hawky 1.8 Liter Turbo 4 02-06-2006 04:36 AM
Automatic Trans. problem? CyberGrnBug01 Transmission Talk 7 01-08-2006 05:42 PM
Trans Fluid Flush bugasm99 Technical Modifications 5 01-02-2006 12:23 AM
