| USA: Southwest AR, CO, LA, NM, OK, TX |
Here you go and welcome to the org!!
Make sure you come back and don't be strangers!! EDIT: Says 2.0, but exactly the same as 1.8Ts
Hi,
Well anytime you work on the new beetle remember its all plastic.. the plastic breaks any time you touch it. I have broken almost all the head lamp peices at some point. The worst part is that the lever is usually stuck and wont move without force that will break the tab off. I suggest spraying some wd 4o in the track or groves that will free it up a bit. The actual bulbs are easy to replace. its the head lamp assembly that is very expensive. Take your time invest in a Bentley published manual if you are keeping the car. they are around $ 70.00 but worth all that money in knowledge.. Good luck
http://newbeetle.org/forums/parts-accessories/44158-unofficial-newbeetle-org-decals-6.html Yes, Im in love with the Beetle. I have owned the NEW Ringo, Rico, JYD, and Peppy Pepper. I love this site and the people that come with it. I hope to see you and your beetle at a GTG soon. |
That plastic piece you broke is roughly $16 at your dealership. They should have plenty in stock because they are so often broken. ![]() |
| Headlight Replacement- HELP! | peapodtdi | Questions, Issues, Concerns, or Problems with the New Beetle | 13 | 08-04-2011 12:55 AM |
| Headlight replacement | Barnum | Technical Modifications | 9 | 02-20-2011 03:13 PM |
| Replacement Headlight Assemblies | Chucktastic | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 09-30-2008 01:52 AM |
| headlight replacement | dieseldiva | Technical Modifications | 19 | 02-13-2008 01:23 AM |
| 2006 headlight replacement? | josigna | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 11-12-2007 03:07 AM |
