DZLBUG's Silver Arrow 2000 GLS TDI - NewBeetle.org Forums
Old 08-24-2008, 06:30 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
Default DZLBUG's Silver Arrow 2000 GLS TDI
2000 New Beetle GLS TDI
Old 08-24-2008, 01:33 PM
Neko-Bug's Avatar
Garden City, MI,
Car: 2000 Red GLs
Lookin good!
No amount of time can erase the memory of a good cat... And no amount of masking tape can ever totally remove his fur from your couch... >^..^<
I'd rather laugh in my VW than cry in a limo...
"The World is a book, and those who do not travel read only a page." St Augustine
Old 08-24-2008, 05:04 PM
AlienBug2000's Avatar
Seymour, CT, USA
Car: 2000 Silver Arrow TDI
Woohoo! Another silver Y2k TDI.
What could possibly go wrong? Now hold my beer and grab the video camera.
My AlienBug: http://newbeetle.org/forums/photos-new-beetles/29966-dons-2000-silver-arrow-tdi-alienbug.html
Old 08-24-2008, 07:06 PM
mombug's Avatar
Topless Forever
Summerville, SC, USA
Car: 2008 NBCSE Gecko Green
Nice shots! Does he play hide n seek in the grass with you very often?
"Pain, when it heals, becomes wisdom. Let go of the pain, and keep the wisdom..."White Crane - Kung Fu Killer"
"Being middle aged and old takes up most of yer time, don't it?" Ringo Starr in "A Hard Days Night"
Old 08-25-2008, 04:16 AM
callisto9's Avatar
Good-bye Curby...
Bettendorf, IA, USA
Car: '08 Scion xB - "Artie"
Excellent pics! I love the rims and of course, I'm partial to silver.
Me (Erin) ~ My car (Curby)
(o\_vw_/o) Beetles rule!
There's no apostrophe before an 's' when you're talking about the plural version of a word. "I took some neat photo's!" is NOT correct.
Old 08-26-2008, 05:00 PM
chiltepin's Avatar
Orlando, FL, USA
Car: 2008 New Beetle S
Cool Contrariwise
I'm not partial to silver, but on these photos, the color looks more like pewter (a pretty color).
!Vivan los vochitos!
Old 09-12-2008, 04:36 PM
Beetlescott's Avatar
USS ERNIE PRISE NCC 1701
LOUISVILLE, KY, USA
I love your Bug! The pics are awesome, I love the fence and field. I am a new owner of a Silver Arrow Beetle and since I am, I have been noticing more and more Silver bugs. AWESOME!
Old 12-14-2008, 09:05 PM
DZLBUG's Avatar
I Am Breitbart
Default Winter Mode
My car has been undergoing some changes lately, just in time for the white stuff.
Here's the list of recent changes:
- Metalnerd 2" lift
- Springs from a 2004 Jetta GLI VR6 (front color code: 2 blue/2 white, rear color code 3 green/1 silver)
- Koni Special Reds (rears are longer wagon version to help avoid topping out) at factory full soft setting
- 205/70/15 Nokian Hakkapeliitta RSi snow tires on Avus rims (summer tires will likely be 215/60/16 for a very similar diameter). Stock size was 205/55/16.
- Final lift (suspension and tire) numbers: 3.25 inches up front, 4 inches in back.
You may also notice my damaged front valance and bumper. This was thanks to a hay bale that had fallen onto the highway and that I was unable to avoid due to traffic circumstances. The 65 mph impact cracked the valance, wrecked the pass. side foglight, screwed up the plate bracket and put tons of spider cracks into the bumper cover. I'm thinking a Turbo S bumper may find its way onto my car sometime soon.
Old 12-17-2008, 05:35 PM
Kuplamies's Avatar
Old & New Beetles
Finland
Car: 99 silver tdi
I love those summer pics Very gooood photography!
And the winter pics: at least now you have got enough of ground clearance! I like it too. I am planning to lift my Beetle also. But my goal is to lift it only appr. 2 inches.
Old 12-17-2008, 06:57 PM
Tesla's Avatar
Y2K Speedle
Car: 2000 Beetle 2.0 Manual
Great Bug!!! ... and nice lift too! Is your speedo off with bigger overall wheel size and how much? Does the bug wobble?
Keep up the good work dude!
Go out and ride
SPEEDLE
Old 12-17-2008, 08:48 PM
DZLBUG's Avatar
I Am Breitbart
Actually the speedo is now dead-on because they are set by VW to under-report actual speed. I do have to apply a correction factor to my odometer though. 10,000 miles on the odometer is actually 10,571 miles now.
What do you mean by wobble? Handling is still very good, even with the taller snow tires. The Koni Reds and stiffer springs make for excellent cornering and handling.
Old 12-18-2008, 05:16 PM
Tesla's Avatar
Y2K Speedle
When you brake, does it nose dive and when you take corners, does the bug lean too much? I went form standard high to 1.5 inch lower ( Eilbach Kit Pro ), and I love the way bug handles on the highways, but on the other side I hate rough ride, pot holes and cracks on the road. I mainly drive in the city and it's BAD! 2 inches lift will put me in the comfort mode ( and I love the way it looks ) but I don't want to wobble to much.
What kinda of KYB-s you have? Are they made for New Beetle specifications or you have something that fit the length of new springs? Mine are KYB AGX, adjustable and it helps a little when set to softest.
Old 12-18-2008, 05:32 PM
DZLBUG's Avatar
I Am Breitbart
Well seeing as how it is winter and I have higher profile snow tires on, I havent really tested the braking and handling capabilities too much. However, from what I have done...it really isnt any worse than it was stock. Once summer comes around and I get the snow tires off I'm sure it will prove to be better.
Now, it may not corner or brake as flat as a lowered car might, but the ride will definitely be better than a lowered car. And I think with the addition of the stiffer springs and the adjustable Koni Special Red shocks/struts...there will probably be an improvement over stock in terms of handling.
The shocks/struts are not KYB, they are Koni Special Reds as I mentioned. Koni yellows may also be a good (albeit stiffer) choice. The Reds are adjustable, however they must be taken out of the car to be adjusted. I have mine set to full soft currently, but I plan to take them out between 50-75k miles and turn them up a bit as they wear in. Knowing what I know now, I probably would have had them set 1/2 to 1 full turn stiffer. The shocks/struts are all the same on all A4 chassis cars (all NB's and 99.5-2003 Golfs and Jettas), however the Jetta Wagon uses slightly longer rear shocks. This is not required with the lift, though I thought it might be a good idea with the use of the stiffer/taller VR6 springs that I used. The longer shocks help to keep the suspension from "topping-out" on large bumps/dips. Using the wagon shock did not provide any extra lift considering that the Koni Reds are strictly hydraulic dampers and not gas-charged like say a Bilstein HD.
Old 12-18-2008, 05:52 PM
DannyRandomState's Avatar
Tired.....
State Of Confusion, USA
Car: Wasabi
Those are some sweet pics!
I'm really diggin the lifted look too.
3-5 Trucks!!!!!
Old 12-18-2008, 08:13 PM
Beltaine's Avatar
You've got a set of McNally gauges, right?
How do they match the OEM blue with red needles?
Thinking about picking up a couple of them.
Old 12-18-2008, 10:52 PM
DZLBUG's Avatar
I Am Breitbart
The blue matches quite well. The needles are more orange than red. I don't really notice it much being that the gauges are so far from the cluster.
To me it is a non-issue. The quality and customer service that McNally provides is second to none. Great gauges, I get vital data from 6 different sources in 3 gauges. They also provide all the sensors and everything you need except for the pod itself.
VDO, Stewart Warner and all the others are crap in comparison.
Old 02-24-2009, 02:02 AM
Very nice! Thanks for all your help recently BTW.
2006 New Beetle TDI 5spd, Cream Exterior/Beige Leatherette Interior, Monsoon CD/MP3/SAT, Sunroof. 43K+ Miles on the clock. UNIDEN 538W CB, Firestik 3' Antenna, Hardwired Valentine1 X/K/Ka/Laser Radar Detector,ProParts Dual Gauge A-Pillar Pod with New South Indigo Boost & Water Temperature Gauges, connected to the dimmer switch for a perfect factory gauge match. Watch the video clip! http://www.youtube.com/watch?v=-iZv39lnmAs, Hardwired Craftsman Garage Door Opener
Last edited by CrazyJames; 06-09-2009 at 03:45 PM.. Reason: quoted pics removed at OP's request
Old 06-09-2009, 03:23 PM
DZLBUG's Avatar
I Am Breitbart
Have added a few things lately...
Cheap $20 side-exit exhaust mufflerectomy. This is just a trial run before doing a full 2.5" mandrel bent stainless steel side-exit exhaust behind a TDIparts.com downpipe. Final version will have a 3" turnout tip. I'm loving the side-exit so far. The turbo whistle is sweet. No drone, very quiet while cruising down the road. Has a nice note when you put your foot in it. Car and wheel stays completely clean, no more soot on the back end.
Finally painted up and installed my Bernt pod. Krylon Indoor/Outdoor Flat Black is a perfect color/sheen match for the factory rubberized dash paint.
Installed a stealth race pipe...aka modified and gutted EGR valve. Anti-shudder (and anti-runaway) valve is still intact and functional.
A little off pavement fun, my car is often my transportation while out doing farm work with my dad.
More off-roading:
Whaddya think...will it pull?
The tractor that pulls this has 180 HP (with unknown but gobs of torque.) When fully modified my car should have about 180hp and 350 ft-lb. Traction, gearing and hookup might be an issue though. Just kidding...
That is about all for now. I have many plans and dreams for this car. Only limit right now is funding as my job search goes on.
Coming soon:
5 speed swap with DC Stg III clutch, DG short shifter and .717 5th gearset
Full 2.5" exhaust
Oversize 205/65/16 tires
Wish list:
Nozzles
Rocketchip tuning
VNT 17/22 turbo running 25 psi
Tyrolsport SMIC and vented fender liner
Peloquin LSD
ABD Cup front bumper
Custom rally style lightbar/bumper guard with HID floods
17" Rial "Lugano" (turbine style) wheels with 225/55/17 tires
Full black interior with Katzkin seats
35&% tint
The list goes on...
Old 06-09-2009, 03:59 PM
Yello_jellybean's Avatar
Can you handle it??
Denver, CO, USA
Car: 2005 Platinum Grey TDI GLS /DSG
Awesome DZLBUG!! LOL! I love the shots in front of the plow.
You are my TDI inspiration.
Old 06-17-2009, 03:50 AM
DZLBUG's Avatar
I Am Breitbart
I trolled (jokingly) in a vortex thread and got this in response.
I LOL'ed!
Don's 2000 Silver Arrow TDI, AlienBug AlienBug2000 Photos: New Beetles 24 04-16-2010 12:32 AM
2000 Silver Arrow 1.8T EL BOLILLO zadiel24 Photos: New Beetles 3 02-02-2008 09:42 PM
wtb silver arrow mudflaps angelusnhc Market Place Archives 9 06-15-2006 06:52 PM
Porkchop ~ 2000 Silver Arrow GLS 2.0L Porkchop Photos: New Beetles 6 01-07-2006 11:57 PM
VW2.0 Driver - 2000 Silver Arrow 2.0 New Beetle GLS VW2.0Driver Photos: New Beetles 21 11-05-2005 01:51 PM
